Old 05-18-2016, 08:23 PM
Efi69Cam Efi69Cam is offline
Default DSE subframe spring rate
My DSE frame was originally ordered for a BBC and was shipped with 525lb springs. I have switched plans and am going to install a wet sump LS7. I noticed on the DSE site that the current specs are 550 for SBC/LS and 650 for BBC. Is the spring rate increased due to some other change in the frame or shocks? Will the springs I have be acceptable with the ls?
Old 05-18-2016, 09:56 PM
frankv11's Avatar
frankv11 frankv11 is offline
My DSE sub came with 8" 450s for Ls but with super charger and heat exchanger Etc .. It's no Bueno . So I called and they recommended 650s. Give them a call they great to deal with .
Old 03-16-2025, 10:18 AM
thedugan's Avatar
thedugan thedugan is offline
Resurfacing an old post. How did the 650pound springs work for you. I am running an LSA in my dse frame and the current springs are maxed out on height. I need to raise my front end am inch with some new springs.
Doug L.
68 Camaro RS/SS Conv. LSA/T56
67 Camaro RS LS2/T56 "NutKse"
