Old 06-18-2016, 12:16 PM
GPR's Avatar
GPR GPR is offline
Default SPI Viper Red 1965 Mustang painted 9 years ago
We are going to be changing the front nose and getting rid of the large spoiler
We will also modify the rear bumper to get a better fit and paint body color.
Rusty Gillis
Gillis Performance Restorations
Port Richey Fl
www.gillisrestorations.com
Old 06-18-2016, 11:18 PM
It still looks great.
Old 06-21-2016, 07:09 AM
GPR's Avatar
GPR GPR is offline
This is the first test fit of the customer supplied Stangaholics front apron. I had to do a lot of fiberglass grinding to clear the electric fan. It still needs to go down on the right side and up on the drivers side.
Rusty Gillis
Port Richey Fl
Old 06-25-2016, 11:29 AM
GPR's Avatar
GPR GPR is offline
To get the front end to line up better Brian had to adjust the fenders.
I had to add a little filler to match the fenders
Epoxy primed
Rusty Gillis
Port Richey Fl
Old 06-25-2016, 11:53 AM
GPR's Avatar
GPR GPR is offline
Brian cut the ends off the bumper and lined up the center
Since the bumper was narrow we had an old bumper that he cut out a section and welded to the back
Reshaping the end
Now he can screw it together to test fit
After a lot of welding and grinding
Epoxy primed. Next week I will do a little bodywork
Rusty Gillis
Port Richey Fl
Old 06-30-2016, 03:56 PM
GPR's Avatar
GPR GPR is offline
Test fitting the bumper after a little bodywork
Epoxy primed
Rusty Gillis
Port Richey Fl
Old 06-30-2016, 05:39 PM
Centerforce's Avatar
Centerforce Centerforce is offline
The bumper came out looking flawless! What else do you have planned besides the front end changes?
Old 07-01-2016, 06:42 AM
GPR's Avatar
GPR GPR is offline
That's all we are doing and it goes back to the owner.
Rusty Gillis
Port Richey Fl
Old 07-08-2016, 10:52 AM
GPR's Avatar
GPR GPR is offline
I added a couple of L brackets that will bolt to the radiator support
SPI white epoxy
I wet sanded lightly with 600 and sprayed 3 coats of SPI Viper Red yesterday and today sprayed SPI Universal clear
Rusty Gillis
Port Richey Fl
Old 07-08-2016, 01:09 PM
I like the changes. Makes for a more complete and smooth appearance.
