Old 07-20-2006, 09:51 AM
Default Is 9-10" front wheels possible with stock sub?
I was reading details of DSEs superb new front subframe and notice it takes 18" x 10" wheels! So there is possible to use 285x18 " fronts? What is the widest front wheel wich can be used with stock 1969 camaro subframe ,if equipped with DSE A-arm,coilovers and unisteer r&p ?
63 Z06
Old 07-20-2006, 01:32 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Control arms, and r&p don't help in the effort of using a wider wheel with a stock subframe. The frame itself is the limiting factor.
CarlC is running a 9.5, under his '68. But the turning radius is reduced, you must use short steering arms, and the tires will hit the frame at full lock.
DS&E subframe is a whole different animal.
