Closed Thread
Old 07-26-2016, 11:26 AM
6t9 camaro's Avatar
6t9 camaro 6t9 camaro is offline
Default 1969 Camaro 427 (Aka Sinister )
Item Location (City/State): Winnipeg, Manitoba Canada
Price:$89,000US SHIPPED! (within USA or Canada) OBO
Description:
1969 Lsx 427 Turbo 5spd Camaro
This is one fun fast and reliable Camaro! I built this car to be a turn key go anywhere car and thats what it is! Hop in turn the a/c on and go for a cruise or head to the track! It started out as complete rust free California Camaro that retains all of its original Gm metal. Car was stripped to bare steel and sealed with the best PPG primers and paint! Underside is lizard skin sound and thermal coated, Body is straight and secured with DSE subframe connectors, 8 point cage, DSE Mini tub kit, DSE Quadralink suspension outback with Martz Chassis coil over suspension and Rack and pinion subframe up front. Baer track claw brakes with hydroboost. Wheels are Custom Rushforth Whiplash with smoked titanium centres and polished lips. Front are 18x8, Rears are 19X12's. Tires are Nitto NT05's 245/40/18 and 335/30/19.
Interior was setup to have a stock feel With factory style door panels but all the modern comforts! Vintage air A/C and heat, DSE body colour dash panel with Custom Speed hut Gauges with GPS, Factory GM tilt, Momo wheel with quick release, DSE 6 speed wiper system, Sony Stereo system, Full dynomat throughout (floor, roof,firewall,trunk) Leather Bucket seats with custom matching rear seat (custom built for cage bars). New American auto wire harness front to back integrated with the Holley Dominator Ecu and harness.
Now for the best part the powertrain! Engine is a ERL Performance built 427 Dry sleeved LS Block (LS3) M1 turbo package spec'd to run in the 600 to 1000hp range, Wiseco pistons, Callies Rods, Callies Crankshaft, Arp bolts through out! Cylinder heads are LSA castings built by West coast Racing (ALL-PRO) stage 2 porting with Inconel valves, Dual springs and CHE precision rockers. Radiator is a Custom size (max size) LS Unit with dual fans built by Auto rad.
Transmission is a Tremek 5spd TKO600 beefed up by American powertrain, Clutch is hydraulic with a bully stage 4 disc and pressure plate ( i can get full specs if need be).
Differential is a custom built Narrowed Moser 12Bolt with 3:73 Gears and Eaton posi unit with 33 spline axles.
Turbo system is a 78mm precision turbo fed by custom built stainless headers, Custom built oversized interintercooler. Exhaust is also custom 5" stainless pipe to a mid car Borla Xr1 muffler then splitting to dual 3" pipes and 2 more Borla Xr1 Mufflers then tail pipes. (its nice and quiet or loud when it needs to be !)
Fuel system is a Custom built stainless tank with twin bosch in tank pumps built by Ricks Tanks capable of feeding approx 1200hp. Holley pressure regulator, Fuel rails, Bosch injectors. Computer system is a Holley Dominator ECU and is Drive by wire.
I never thought i would put this car up for sale! Ive had and been working on this Camaro for over 15 years and built it to keep but plans have changed and its time for it to go.
I know I'm going to forget some stuff but i have tried to list as much as possible about the car. If your interested the complete build thread is here in the forums (link in signature) plus i can send pics or vid of anything you might be interested in.
-ERL Performance built LSX427 (dry sleeved LS3 Turbo Package) Currently Approx 700RWHP
-LSA Cyl Heads New Reworked/ported from West Coast Racing (WCCH) Precision -Comp cams turbo spec Camshaft.
-78mm Precision Turbo
-Custom stainless turbo headers/Exhaust.
-Ricks tanks stainless fuel tank, twin in tank Bosch pumps.
-Holley Dominator ECU/Wiring.
-Alum Radiator Custom built by AutoRad with Dual fans
Transmission
-TKO600 (5spd) Built by American Powertrain
-Wilwood Hydraulic Clutch
-Stage 4 Bully clutch/pressure plate
Rear end
-Moser Narrowed 12 bolt
-3:73 Gears
-Eaton Posi
-33 spline axles
Suspension
Rear
-DSE Quadralink
-JRI Coilover shocks
Front
-Martz Chassis Subframe
-Qa1 Coilover shocks
-Rack and pinion steering
-Speedway Engineering sway bar
-Baer Track claw Kit 13" Rotor front, 12" Rear.
-Wilwood Master cyl and adjustable prop valve.
-Hydroboost by Hydrotech.
-Lokar e-brake
Wheels/Tires
-Rushforth Whiplash wheels with smoked titanium centres and polished lips.
Front
18x8 with Nitto NT05 245/40/18 tires
Rear
19x12 With Nitto NT05 335/30/19 tires
Body
-Rust free California shell.
-Original Quarter panels,Floors,Fenders,Doors, all original metal except Fiberglass hood and trunk lid.
-Fiberglass Foose hood, Fiberglass trunk lid.
-Marquiz designs front valance.
-Bumpers have been smoothed and Painted/chromed
-Paint PPG Base clear space grey metallic
-Detailed Base clear Engine Compartment
-Mikes custom cars firewall filler panel (to retain firewall body lines)
-DSE subframe connectors run through floor to sub-frame
-DSE Mini tub kit
-8 Point chromoly cage tied into rear frame rails and front subframe.
-Full AAW wiring harness
-Original GM Nos stainless trim,(drip rail,wheel well openings)
-full stainless bolt kit
Interior
-DSE Gauge panel
-Custom Speed hut Gauges w/gps
-Vintage Air A/C and Heat
-DSE 6 speed wiper system
-leather sport lumber seats
-Leather Momo steering wheel with quick release
-Sony stereo
-Fully Padded cage
-Dynomat everywhere!
I could go on and on! but check out the build thread as theres list of pics and info i probably didn't mention here! The car is located in Winnipeg Manitoba Canada and can be viewed by appt or like i said i can send any info or pics/video needed! I can also help in anyway possible with shipping so it gets to where its going safely! The car currently has just over 2000 trouble free miles on it and is not going to be used until it is sold. You can reach me through the forum or e-mail at [email protected]
Thanks for looking!
C Wall
69 Camaro (Sinister) Build
https://lateral-g.net/forums/show...light=sinister
Old 07-26-2016, 11:30 AM
6t9 camaro's Avatar
A few More
C Wall
Old 07-26-2016, 02:52 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
GLWS,very nice car at a good price.
Old 07-28-2016, 10:39 AM
6t9 camaro's Avatar
thanks tubbed69 I'm going to be sad to see it go!
Ive been asked for a couple more pics so i figured id post them up here.
C Wall
Old 07-31-2016, 08:40 AM
Rybar's Avatar
Rybar Rybar is offline
GLWS that is is very nice build! Coming from a fellow Canadian on the west coast.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 07-31-2016, 10:32 PM
chichirone's Avatar
chichirone chichirone is offline
GLWS! Beautiful car.
Jay
1973 Trans Am "KLRBRD"
1969 Camaro SOLD
2014 Stingray Z51 SOLD
Old 07-31-2016, 10:59 PM
califconstruct's Avatar
califconstruct califconstruct is offline
Nice Ride..!
Old 08-01-2016, 02:34 PM
6t9 camaro's Avatar
Thanks Rybar!
Your making me jealous thinking about cruising on the West coast!!!
C Wall
Old 08-01-2016, 02:35 PM
6t9 camaro's Avatar
Originally Posted by califconstruct View Post
Nice Ride..!
Thanks Guys!
C Wall
Old 08-01-2016, 05:11 PM
camarodude87's Avatar
camarodude87 camarodude87 is offline
I didn't see in your thread but what fuel tank is in the car? Thank you
Closed Thread
