Old 10-04-2016, 05:55 PM
Default Sealing extra 02 bung
I have a couple of 02 bungs in my headers that won't be used.(Not enough room for sensors) When I put the plugs in do I put high temp RTV on the plugs to seal them or something else or nothing? Copper crush washers?
Old 10-04-2016, 07:30 PM
Che70velle's Avatar
Wayne, I went with Mast M90 electronics that only required one O2. My other header, I used an allen head pipe plug and ran it in tite, with nothing on it. I thought about sealant, but wasn't sure anything would hold up very long with header heat. I have no issues at all, although if I needed it to come back out, I'd probably be in trouble.
Thanks Dad!!
Old 10-05-2016, 02:30 PM
novahollic's Avatar
novahollic novahollic is offline
Put some copper anti seize on it. It will hold up to the heat, but still allow it to come off in the future.
Old 10-05-2016, 08:39 PM
randy randy is offline
I used the aluminum gasket silicon thay came with my headers
Old 10-10-2016, 04:51 PM
andrewb70's Avatar
If you don't have a proper plug, the large thread spark plugs work just as well.
Andrew
Old 10-11-2016, 06:22 AM
CJD Automotive's Avatar
CJD Automotive CJD Automotive is offline
I would use a copper crush washer from a banjo fitting. I've used the plugs before and always use a sealing washer, especially if it's upstream of the O2 your using.
If you can't find one, you could grind down the threads on a spark plug and slip the crush washer off. It's the same size as the plug.
Craig Scholl
CJD Automotive, LLC
www.CJDAUTOMOTIVE.com
"I own a Mopar, so I already know it won't be in stock, won't ship tomorrow, and won't actually fit without modification."
