Old 07-26-2006, 08:16 AM
31 SONIC 31 SONIC is offline
Default DSE wheel tubs ??
DSE wheel tubs @ $400 VS. standard steel tubs @ 80.00
I'm not concerned about the OE stamped look
Are the DSE tubs THAT much easier to install to justify $320.00 more in cost?
Old 07-26-2006, 10:06 AM
XcYZ's Avatar
XcYZ XcYZ is offline
The DSE price of $400 is for the pair. The $80 you quoted for the factory inner wheel house is for each, so make that $160. But anyways, it's up to you how much you want to cut and weld, there are plenty of guys fabbing their own.
My LS7 69 Camaro
Old 07-26-2006, 10:36 AM
907rs's Avatar
907rs 907rs is offline
The extra money I spent for DSE tubs was well worth it in my time alone. If you're going to mini-tub, the less time you have to spend in the trunk the better.
Bill
Old 07-26-2006, 10:55 AM
Thanks guys, the DSE's are it. You get what you pay for, right.
Old 07-26-2006, 07:36 PM
awr68's Avatar
awr68 awr68 is offline
I did mine using new inners and some 18 gauge years before the Deep Tubs were availale, the way DSE used to do it...it easily doubled the time it took to do the mini-tub job...next time I will use the DSE tubs for sure!!
Tony
'68 Camaro
Old 08-01-2006, 11:23 AM
aonghus's Avatar
aonghus aonghus is offline
yep, quality only costs when you don't spend enough the first time!
