Old 01-22-2017, 04:51 PM
Gregster1234 Gregster1234 is offline
Default Camaro bodies-Real Deal Steel
Would it be better to get a complete body or restore mine which needs quarters, floors, fenders, doors, minitub, etc. It seems cheaper than having a body shop perform all this. I know there is a jig for 1st gen Camaro but this company has a jig for every area to keep car in tolerance. I am unsure which way to go. Obviously would like the best resilts at the least amount of issues and surprises. I watched the video at Real Deal Steel and it is impressive. Any input would be awesome.
Old 01-22-2017, 06:29 PM
DT69Cam DT69Cam is offline
Without pics its your call. I would try to keep yours. Check out the AMD installation center. http://www.amdinstallation.com/#dashboard:Home
69 Camaro Convertible (LS3/TKO in the works)
Old 01-22-2017, 08:48 PM
vipercuda vipercuda is offline
I can't speak to Real Deal's Camaro but I can talk of their 57 Chevy & the car had to be cut apart because the panels didn't line up at .
If you were coming to my shop I would advise you to use your car or be prepared to buy theirs then fix their body.
I would be happy to connect you with my customer to get his thoughts on a Real Deal body.
Good luck
Mike
Old 01-24-2017, 07:08 AM
If you're paying for labor, you will be better ahead to start with a solid car. You can pick up a solid 70-73 for around $10k to $20k depending on the car. If you dive into a car that needs everything replaced, you're looking at hundreds of hours in labor and in the end you'll have a made in China camaro
Old 01-26-2017, 06:34 AM
Any recommendations on a body shop around St.Louis, MO? AMD installation center looks great for the sheet metal installation.
Old 01-30-2017, 04:24 PM
Nativefx Nativefx is offline
Another place to consider that I have heard good things about is Muscle Car Metal. I don't have any direct experience with them, but there are a couple people over on Team Camaro Tech that have used these shells from Tony. I wish I had known about them before we ended up replacing so much of the sheet metal on my firebird as it would have been a better starting point, or at least maybe sped up the process. His are refurbished originals, so they come with titles.
http://www.musclecarmetal.com/home2.asp
