Go Back   Lateral-g Forums > Classifieds > What's it Worth
Old 02-07-2017, 07:13 AM
grendel grendel is offline
Default 1987 Monte Carlo SS
T-tops, fully loaded, everything works, no rust (we cut it all out).
Nice paint, 10 footer. Cheesy SS stickers are there, but I'd take them off and stay with the gray paint after a nice buff job.
Now for the goodies:
Very fresh L33 5.3L, with a single H1E turbo, injectors, GM LS7 cam, GMPP roller rockers, gm gaskets and seals. Dyno tuned, 547RWHP.
Turbo hot side is all stainless, with factory manifolds (truck on one side, LS4 on the driver's.) with v-bands and flex couplers. Cold side is all welded aluminum, with a Tial blow off valve set to 10psi. Everything will be coated/wrapped to keep under hood temps down.
Replace the turbo with a GT366SXE and bigger injectors and it's 700-800hp to the wheels. The T4 based plumbing with a honking charge air cooler in front of the electric SPAL fans will support 1KWhp. We used flat tops in the L33, it's limiting factor is 800ish RWHP. It has a 3 BAR map, 2015 Vette MAF in a z06 air intake, which will also support a lot more. We had the turbo and 58lb injectors.
4L80e, billet converter (revtech), billet input and output shafts, fresh build, transgo stage 2 valve body (have a manual shift kit if you want it).
GMPP Ford 9" housing, 3.50 gears, Detroit true-trac LSD, 35 spline chromo axles, Wilwood 14.4" brakes, 6 piston calipers, parking brake. Currie/Ride tech brackets, Ride tech single adjustable coil overs.
Ride Tech front A arms, coil overs and steering, 98 S10 2WD spindles, Wilwood 14.4" brakes, 6 piston calipers.
Ride tech single coil overs on all four corners.
Baer re-master
Vintage Air under the dash. All factory gauges work, EFI via a GM 0411 computer and stand alone harness.
Soon to be 315's square on 18" rims
1.5" Chromoly cage, TIG welded while the floor was out. Factory seats for now.
Should be noted that we're building this out of parts we have around the two shops, mainly to sell. All professional fab work and design.
What's it worth? We're still building it, so things can change.
My garage builds, with some hack and professional love thrown in:
68 GMC C1500
Haulin more than the mail
73 Camaro
Better grow a mullet
70 K5 - 4wd turned 2wd
Project might as well...
Known as John or "JJ"
Old 02-08-2017, 10:40 AM
syborg tt's Avatar
Thinking 12 to 15
marty-mj
