Old 07-31-2006, 05:27 PM
tumper93 tumper93 is offline
Default How to make DSE subframe connectors bolt in?
I have installed my DSE subframe connectors but don't want to weld the subframe to them because I may need to remove it or drop it to put a clutch in or something in the future. I know that Scott Gulbranson has done it but I am not sure of how he did it. Should I install crush tubes or cut the bottom out of the connector and weld nuts on the back side? If I put crush tubes in what material should I use? I would appreciate any help, I will be doing this tomorrow so I can remove the subframe and have it powder coated soon. Thanks.
Old 07-31-2006, 06:25 PM
I see how you did yours but I have cut the end of my subframe connectors so they are about 1/2" from the subframe itself and I will be welding the attaching ears from DSE tomorrow. Mine will have to be reversed from yours but I figured the easiest wat would be to just use a crush tube so the connectors don't crush in when tightened. I was just wondering how others had done theirs.
Old 02-05-2007, 10:04 AM
5th Gen 5th Gen is offline
I know this post is a little old, but can someone tell me how to do this as well. Thanks
Old 02-05-2007, 05:29 PM
ItDoRun's Avatar
ItDoRun ItDoRun is offline
Originally Posted by Sparky67
I sent you a email on how to make the sub frame removable. It is easy to do.
Jeff
Jeff,
Shoot me some photos. I'm planning on doing this as well.
Thanks,
Chris
Old 04-16-2007, 06:36 AM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
Can you send me some info as well please. I'm getting ready to start
Jeff
69 RS Ragtop
[email protected]
Will trade wife for parts!!!
