Old 02-19-2017, 12:05 PM
vstol vstol is offline
Default TKO-600 5 spd does not shift
I got a TKO-600 5 spd from American Powertrain trans a few years back for my project. Well I finally got to bleed the hydraulic bearing today and the car does not shift into gears. In fact when I first got it home and installed I could barley get it into gear sitting on the frame, they said that would be ok. Well the car is finished and I am ready to get going but I am totally stopped. I will contact American Power Train tomorrow but in the mean time looking for some serious help. Thanks
Old 02-19-2017, 02:29 PM
bulldog19 bulldog19 is offline
i had similar issue with tko600 and the pressure plate was stuck as a result of the car sitting. I found that letting engine run and getting up to operating temp it would free itself
John
68 Camaro RS Convertible Dual Quad 406 TKO600 Hotchkis TVSS SOLD
Old 02-19-2017, 02:44 PM
It has been sitting for a while but I have at least 50 start ups in the last 6-7 months to operating temperatures. Thanks
Old 02-19-2017, 04:10 PM
This may sound hokey, but can you get the car rolling, then push on the shifter? (This assumes that you've got your driveshaft hooked up.) A transmission's inner parts like to move--if you do this right, no manual transmission needs a clutch for anything other than getting going. If you get rolling, you don't need the clutch to get into gear--first gear won't require much speed at all. Every gear has a road speed where it will just slip into gear (and out) with little (some) resistance (and no clutch disengagement). You also will not need much force at all; this is not a suggestion to apply violence . . .
TKOs and T5zs can be very sticky when new. Industrial boxes can be so much worse . . .
Old 02-19-2017, 06:31 PM
Thanks its on jacks right now but I will keep that in mind.
Old 02-19-2017, 06:47 PM
They don't shift worth a damn when they work right either. Sorry, couldn't help myself.
Old 02-19-2017, 10:00 PM
Flash68's Avatar
Flash68 Flash68 is offline
I was waiting for that post!
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 02-20-2017, 05:28 AM
That's what I was waiting for as well. Too late now, but it should shift with no engine start ie: while just sitting there correct? I spent a very long time setting up the hydraulic clutch so it frustrating. The car is on jacks so I am wondering if and when I sit it down it might break the pressure plate away if that's the issue. It will have resistance then.
Old 02-20-2017, 09:07 AM
I spoke with American Power Train and they said I need to remove the cover and ensure the linkage is all in the neutral position. That looks like I will need to cut my tunnel and maybe my dash. I have not walked out to the garage to take a look as I might get to pissed off
Old 02-20-2017, 10:37 AM
You should be able to shift it sitting there. Especially with the clutch pedal pushed in. You can have someone depress the pedal and check for air gap on the clutch. Take a .020 feeler gauge and see if it will fit. I don't recall, but I think the TKO 600 likes .060 of air gap for best shifting. Bottom line, with an air gap, the trans should shift. I do recall one other person having a two 600 get stuck in gear. Maybe it's related.
I put carbon fiber synchros, shifter, and adjusted the air gap, I still wasn't happy with mine. They are strong and it may suit you fine. They just don't shift quickly and at high rpm well.
