Old 03-14-2017, 07:58 PM
Shiner's Avatar
Shiner Shiner is offline
Default Will these blemishes make any difference?
Are these blemishes make any difference? 5.3 Block is brand new, can I just assemble or do I need to take it in? Plan on doing a health H/C D1SC or Turbo
1970 Chevelle SS
408 Forged LSX, LSA Blower, 4L80E, Ridetech HQ, Baer Brakes, Weld S71b
1997 Dodge Viper GTS
Heads, Cam, Bolt On's, BBS Wheels, Moton Suspension
Old 03-14-2017, 08:39 PM
I'd smooth them out. You should be able to do it with a dremel or similar. That or have the machine shop debur it.
Old 03-14-2017, 09:07 PM
craig510's Avatar
craig510 craig510 is offline
Dermel sounds too aggressive. A jeweler's file or even some emery cloth should clean it up. Be careful not to scratch the bore.
Old 03-14-2017, 11:01 PM
SlowProgress's Avatar
A fine file, emory cloth wrapped around a wooden dowel, a fine honing stone. Something like that should be fine. You have quite a bit of mild surface rust on the bore. In the process of cleaning that really well you will remove any deburring residue.
Old 03-15-2017, 02:55 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
I agree with Scott, a simple debur is all you need. A dremel will take off too much material and create a bigger problem.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 06-10-2017, 11:12 AM
speed_m5 speed_m5 is offline
debur and run it
