Old 04-03-2017, 08:43 AM
paulk68 paulk68 is offline
Default mounting Poly mount to T-56 hardware
can anyone tell me what hardware and sizes are needed to mount my poly trans mount to my t-56 magnum? my directions say use original hardware but i dont have any of that. Thanks
Old 04-03-2017, 09:39 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
Found this on LS1 Tech, I used the stock hardware and this seem right. I believe Home Depot or Lowes will have these in the parts bins.
M10x1.50x40mm long. I ordered mine from Mcmaster Carr.
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 04-04-2017, 05:35 AM
Thank you Very much!! did you happen to put a washer on there also?
Old 04-04-2017, 10:14 PM
DEIGuy38's Avatar
Yes, i used flat washers on mount to transmission and lock washers at cross member to mount. See the attached from energy suspension
https://www.summitracing.com/parts/e...FQRsfgodfFoN8w
Guy
