Go Back   Lateral-g Forums > Classifieds > What's it Worth
Old 04-19-2017, 08:28 AM
jblaine86 jblaine86 is offline
Default 1969 camaro
Just finished building this 1969 camaro and was wondering what people would think this is worth? Every nut and bolt has been changed and all metal has been replaced/repaired. It was a full frame off restoration on a rotisserie.
Some stats are:
-Quick fuel carburated sbc 383 stroker with comp cam thumpr hydrolic roller cam
-Aluminum head with steel roller rockers
-451 hp/485 ft lbs torque
-March performance serpentine conversion
-Tremec TKO 600
-Vintage Air a/c
-Auto Meter gauges
-Moser 9" rear w/trutrack differential and Richmond gears
-Pypes 304 polished exhaust
-Ricks stainless tank
-Tubular control arm w/QA1 coil overs
-Detroit speed mini tub with 3" drop leaf springs and DSE shocks
-Electric Areomotive fuel pump
-Detroit speed electric RS headlight kit
-Detroit speed wiper motor hidden in cowl
-Painless Performance trunk mount battery harness
-American Racing torque thrust M wheels 17' up front and 18" in rear
-Billet parking lights and tail lights
-Smoke tinted glass
- Unisteer Rack and Pinion
Thanks,
Jon
Old 04-19-2017, 10:11 PM
sd67 sd67 is offline
Great job on the car! So tough to say without seeing it up close, but looks like 50-60k could be had, maybe more.
Old 04-20-2017, 07:15 AM
hifi875's Avatar
hifi875 hifi875 is offline
What ^^^he said. fuel injected ls would help,but that looks really good and has a/c
69 camaro
03 z06
90 mustang coupe
1950 international l110
1993 mustang gt
Old 04-20-2017, 02:44 PM
Thank you guys for your opinions. It was a lot of work but I learned a lot by doing everything myself.
Old 04-20-2017, 08:47 PM
Even more impressive that you did it yourself, so I suspect that you probably could make some money if you got 60k out of it. If you are considering selling, I wouldn't put anymore into it, you probably won't get it back.
Old 04-21-2017, 07:23 AM
That's what I was thinking. I will probably keep it for awhile unless something else comes up.
Old 04-21-2017, 08:29 AM
HarveyT HarveyT is offline
I like the red and black combo. Nice job!
Old 04-21-2017, 11:08 AM
Old 04-21-2017, 08:27 PM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
Car looks great! I would say at least $50k.
Can I ask your opinion of those DSE leafs? Think I need to go that route for now but I'm concerned about ride quality a little. Thanks!
Erik
69 Camaro
Old 04-23-2017, 03:07 PM
Thanks. The ride quality of the Detroit Speed leaf springs is not to bad. The car seems to do very well with them. The ones I put on are the 3" drop which I believe makes the ride a little ruffer then the 2" drop. I did take it out today on a small road course and it did surprise me how well it handled.
