Old 08-03-2006, 02:14 PM
ZZ3ElCamino's Avatar
ZZ3ElCamino ZZ3ElCamino is offline
Default SC&C A-Body Control Arms????
Are there any A-bodies ('67 preferably) using SC&C control arms with the ATS spindles? If there is, can you give me your thoughts about their setup? Thanks!
Old 08-03-2006, 02:32 PM
Derek69SS's Avatar
I have their Stage II package, which includes the SPC adjustable arms, and Howe Tall-Balljoints.
Great quality, and design The only downside is there is no bumpstop (not really needed in droop anyway) and you may have to grind a notch in your UCA mount on the frame.
Overall, I'm very satisfied, and SC&C was a great company to deal with.
Old 08-03-2006, 02:37 PM
From the looks of the control upper control arms, it doesn't appear that the QA-1 coil over setup can be used. Am I right with this assumption?
Old 08-03-2006, 02:50 PM
Derek69SS's Avatar
Upper arms won't have any effect on the use of coil-overs.
Keith Anderson's bad-ass '70 el camino has QA1 coil-overs and SPC adjustable arms.
Old 08-03-2006, 06:16 PM
Oh yeah, sorry I wasn't thinking. For a second I was thinking that the coil over shaft bolts into the upper control arm, but in reality it bolts into the spring pocket on the frame. My bad.....
Old 08-10-2006, 10:47 AM
Marcus SC&C's Avatar
Marcus SC&C Marcus SC&C is offline
Just a quick note. We offer the AFX tall spindles and our adj. upper arms as a package, StreetComp-AFX. They`re a great combination. Also one `64-`67 A body there`s usually no trimming required at all. Mark SC&C
Old 08-10-2006, 12:15 PM
We have a 67 Chevelle in our shop getting the SC&C arms with Tall AFX spindles.
It works great.
Tyler
Old 08-10-2006, 12:44 PM
Tyler, would you be able to send pics of the install ([email protected])? I would like to avoid trimming anything if possible. Thanks
Old 08-10-2006, 01:56 PM
We will posting them on our site after we are done.
It will be in the project section.
Tyler
Old 08-10-2006, 03:11 PM
Awesome, I will be waiting for it! Thanks
