Old 10-08-2016, 08:14 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Default NEW - Moser 7900 - "Bolt-On" C6/C7 Hybrid Floater
C6/C7 Hybrid Floater System -
Installs onto any Rear-End that utilizes the Moser 7900 Ends.
That's right,,,, you can use your current rear-end housing, NO welding & simple installation. BOLT-ON!
Advantages:
  • Bolts to your Moser 7900 Housing End (Chevy 10/12 bolt application now available! https://lateral-g.net/forums/showthread.php4?t=52854 )
  • Reduces/eliminates brake “knockback”
  • Eliminates axle deflection
  • Wheel & tire remains intact should an axle failure occur
  • Front or Rear Caliper / E-Brake Cable Positions
  • Utilizes the robust, zero maintenance C6/C7 ZO6 Hub Bearing Unit
  • Utilizes OEM C5/C6/C7 Corvette, and 5th Gen Camaro brake kits
  • Utilizes aftermarket C5/C6/C7 Corvette, and 5th Gen Camaro brake kits
  • Utilizes your existing BAER / WILWOOD caliper & rotor (some restrictions apply)
  • Super compact design compared to traditional style full floaters
  • All advantages of a traditional style full floater without the maintenance
  • Replacement parts available at local GM dealer or local parts house
  • No modifications required to the hub bearing unit as other kits in the marketplace
Note: this applications has a negative 1/8″ wheel mount surface per side (based on an existing 2.810″ axle/brake offset)
Fitment: Any rear-end housings that utilizes the Moser #7900/Strange #H1143 Style Housing Ends
The Moser 7900 End is very similar to the Big Bearing Ford End since it also has a 3.150" bearing bore, however this Moser 7900 End has the GM brake flange and bolt pattern. If you have this style end you are now able to bolt on a Hybrid Full Floater...
Moser 7900 Bolt-On “Base Kit” (pictured below)
Moser 7900 Bolt-On “Base Kit” (pictured above)
Base Kit Includes:
• (2) Billet Steel, C-Series, Hybrid Floater Adaptors
• (2) Billet Aluminum Caliper Brackets
• (2) C7 Corvette, SKF 33 Spline Hub Assemblies
• (1) Install Kit
• (2) Hub Spacers
• (2) Billet Aluminum Hub Cap Seals
________________________________________
PRICED AT - $1,398.00
Add Axles - $400.00
• (2) Hy-Tuf Full Float Axles
Add E-Brake items - $325.00
• (2) C5/C6 Corvette Complete E-brake Assemblies
• (2) C5/C6 Corvette Parking/E-brake Cable Brackets
Have interest?
Have questions?
Need more info?
Distributor Inquires Welcome!
Old 10-17-2016, 08:34 PM
Default Assembled Pics - Moser 7900 Base Kit
Assembled Moser 7900 "Base Kit"
*Housing Ends for display purpose only - not included...
Assembled Moser 7900 "Base Kit" with optional C5/C6 E-brake Kit
Old 02-09-2017, 07:44 PM
Default In Stock!
In Stock!
Old 06-05-2017, 07:17 PM
Default In stock
In Stock
