Old 07-09-2017, 02:18 PM
Macbuick's Avatar
Macbuick Macbuick is offline
Default 2004r
Hello,
I have installed a 2004R in my 72 Skylark, the gearbox comes from Extreme Automatics and the TV cable is an EZ TV Cable from Bowtie Overdrives.
As explained in both instructions, I replaced the TV spring from the gearbox with the one included in the Bowtie kit.
Everything is in place but I 'm afraid to go further and damage the gearbox....
I don't know how to tune the idle TV position...(ExtremeAutomatics gives an ideal length of 0.840 but with their own spring, not the one from Bowtie ).
I don't know either why it's needed to replace the TV springs...I don't understand why you must replace the TV sping when you change the TV Cable !?
I have another issue with the oil lines going from the gearbox to the radiator, I read that the 2004R has inverted ports compared to the TH350, does it is critical to use the same position as the TH 350 or must I invert the position ?
Thanks for your help
regards
David
[SIGPIC][/SIGPIC]
72 Skylark & 68 Pontiac Catalina+ 71 El Camino
