Old 08-09-2006, 05:14 PM
Opm Customs Opm Customs is offline
Default 4l80e in a '69 camaro
Any mysteries here or is it straightforward?
www.opmcustoms.com
Old 08-09-2006, 06:26 PM
camcojb camcojb is online now
Very close but does fit without surgery. You may have to slightly "clearance" the tunnel where the cooling lines come out for clearance; some do and some don't.
Old 08-10-2006, 09:34 AM
Steve Chryssos's Avatar
I agree. Cars with aftermarket clips where the engine is raised slightly to make room for the rack could require a bit more clearancing. We did a car with a 21st Century clip and half height body bushings. The trans tunnel at the "12 o clock" position needed some minor hammering. Some heat from a torch made the job cleaner and easier. Nothing major.
Also if it an early case, Russell 612000 fittings increase clearance for the cooler lines since they eliminate the need for pipe to AN adapters. The 90 degree fittings themselves thread right into the case.
Nothing major.
________________
Steve Chryssos
Ridetech.com
Old 08-10-2006, 12:29 PM
Default thanks
thanks guys
www.opmcustoms.com
Old 08-22-2006, 07:39 PM
bigtyme1's Avatar
bigtyme1 bigtyme1 is offline
I'm looking into the 4L80e also. Does the 700R fit better? What do you meen buy afteramrket clips?
