Old 10-31-2017, 02:11 PM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
Default New 2nd Gen four link released at SEMA!
Old 10-31-2017, 09:10 PM
Glad to see new, innovative products still being made for the 2nd gens. Will this work with the factory rear end? From the looks of it, the axle tube diameter is all that's critical for connecting up to your components.
Thanks for sharing, Josh. Enjoy your time out there.
Old 11-01-2017, 10:11 AM
Correct! It is set up around a factory rear but has been installed with a 9" set up as well.
and no problem!
Old 11-05-2017, 04:59 AM
bret's Avatar
bret bret is offline
Supporting Vendor
You can use your factory rearend. The oem leafspring brackets will be removed and our upper and lower bar brackets will be welded on. We have jigs available to properly locate these brackets. We also give you measurements and an assembly procedure so you can locate them without the jig.
Ridetech and Currie will be offering complete rearend housings with Ridetech bracketry already installed.
Bret Voelkel
President
RideTech
Air Ride Technologies, Inc.
Old 11-07-2017, 05:04 AM
Thanks Bret!
