Old 12-04-2017, 09:27 AM
elwaupo elwaupo is offline
Default Ford 9” Width
What would be the width for a 9” Ford rear end for a 69 Camaro?
Old 12-04-2017, 04:13 PM
randy randy is offline
Depends on what you are doing.
Stock tubs, wheel offset and width, etc
Old 12-04-2017, 04:30 PM
Replacing my stock 10 bolt using the existing leaf springs. What should the housing size be? How many inches is the width of the housing?
Old 12-05-2017, 06:43 AM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
Wherever you're getting the 9" from will be able to tell you what the stock width is, if you wanted a direct replacement. Many of us narrow the rear end housing a little, for more of a lip on the wheel if you're getting new wheels.
-Dale
SchwartzPerformance
Where classic style meets modern technology.
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 12-05-2017, 07:57 AM
I’m looking at one and it’s 52” from flange to flange and the stock width for the 69 Camaro is 59”.
So 52” should work?
Old 12-05-2017, 06:29 PM
slimjim's Avatar
slimjim slimjim is offline
So 52” should work?
Short answer is yes, 52" WMS to WMS will work, as long as you buy wheels accordingly..
Mine is 53", I also tried my wheels on a 52" rear end on another car, however my wheels are 12" wide with a backspace of 5.25". So if wheels this wide aren't in the plan, then you may want to go a wider rear end.
NC
streamline 68 camaro
Build Thread here
