Old 08-04-2018, 03:03 PM
DanielBurko DanielBurko is offline
Default Wilwood brakes question
WILWOOD BRAKES QUESTION
I am running kit 140-9803 front brakes with spec 37 rotors. We are getting a knocking noise on the drivers side.. under hard braking only not soft braking.
Is this the pads moving because they are not bedded yet?
Any help or suggestions would be appreciated...
Old 08-14-2018, 11:22 PM
65 Drop Top 65 Drop Top is offline
Retorque castle nut in the hub. Is this a new build? It could also be suspension or a body mount that is knocking.
Old 08-15-2018, 03:51 PM
Track Junky's Avatar
Make sure all brake components installed have been torqued to Wilwoods specs then try again. If knocking noise continues insure hubs were secured properly and all other suspension components are in good working order. I'd start with ball joints
Gaetano Cosentino
Old 08-17-2018, 01:34 PM
No it is not -- stop driving it until you find the issue.
Check for "witness marks" on any and all rotating pieces and stationery pieces... it could be a bent wheel that only shows up under duress....
Describe the "knock". Metal on metal - dull - thumping - can you feel it in your feet.... etc. What kind of car.... so we can have a "visual" on all the parts involved.
Old 08-18-2018, 08:25 AM
Blake Foster's Avatar
check that the caliper is shimmed to the correct height had this happened on my Nova first time out and the Rotor was expanding when it got hot and was touching the caliper bridge
just a thought
Blake Foster
www.speedtechperformance.com
Old 08-25-2018, 12:45 PM
Whatever happened with this problem??? did you figure it out?
