Old 10-10-2018, 08:30 PM
sic7camaro sic7camaro is offline
Default Need help, 67 Camaro with rhs 502
When I go to start it, the starter seems to engage the flywheel and spin the motor a little and then a loud bang and it seems like the motor kicks back the opposite way.
Sometimes it will turn and fire up, but seems like it runs a little rough.
Here is a video I made of it. The first two starts are with the coil harness plugs disconnected and it spins the motor fine like that. The others are with them connected and you can see how the motor seems to kick back https://m.youtube.com/watch?v=gmSln5mdTEc
Old 10-11-2018, 07:17 AM
dhutton dhutton is offline
Too much crank timing advance is my guess.
Might be useful to tell folks what EFI controller etc you are running.
Don
Old 10-11-2018, 09:23 AM
Thanks for the reply, okay so it has a pcm out of a 2004 gto and a vaporworx fuel controller, and the pcm has a base tune in it.
Old 10-11-2018, 10:09 AM
What cam? Base tune from a 2004 GTO?
Don
Old 10-11-2018, 04:17 PM
It’s a cam motion hydraulic. I had a base tune done for the 502 motor
Old 10-11-2018, 05:33 PM
I’m no expert but I think the timing is too advanced when cranking. I would get a better tune. Maybe one of the experts will chime in.
Don
Old 10-11-2018, 07:49 PM
Che70velle's Avatar
Don
I completely agree here. You need to get HP tuners/EFI Live scan of your cranking ignition timing, before you try to start the car again. It will likely break the starter boss off the block, if you continue. If it were an Oem block, it already would have broke. Check the timing first. I’ve seen this many many times.
Thanks Dad!!
Old 10-13-2018, 08:29 AM
572Camaro's Avatar
572Camaro 572Camaro is offline
I watched the video.
My guess is you have too much ignition timing advance during cranking.
Please please put a timing light on and check during cranking.
My guess on your application is you want about 15-18 degrees btdc while cranking. That means you want 15-18 degrees between 0-400rpm.
I have a F.A.S.T. fuel injected 572ci 68 Camaro.
I completely shredded my flywheel when it backfired through the intake when I had cranking timing set at 22 degrees btdc.
Please don't do what I did! Ugh.....,
Keep us posted. You have friends you've never met who care!
Last edited by 572Camaro; 10-16-2018 at 09:07 AM. Reason: 28btdc, sorry.., not 22btdc
Old 10-15-2018, 12:06 AM
Thank you for all the help, I will definitely check crank timing this week.
I will let you guys know what I find with that
Thanks again
Old 10-16-2018, 09:15 AM
572Camaro's Avatar
sic7camaro,
I apologize for an error..,
When I shredded my flexplate, the crank timing was 28btdc, not 22btdc like I posted earlier.
Sorry.
