Old 11-29-2018, 05:17 PM
Denver-69 Firebird Denver-69 Firebird is offline
Default ABS Power Brake's Electric High Power Master Cylinders System
Building a '69 Firebird restomod.
Builder has recommended using a electric booster brake system primarily to cleanup the firewall and hide the booster.
When I search Google the only system that shows up is the ABS Power Brake's Electric High Power Master Cylinders Brake System.
It looks like the system has been around for awhile but i cannot find any recent reviews.
Anybody out there using one and how's it working?
Or is there another electric system?
Thanks,
Dave
Old 11-30-2018, 07:25 AM
dontlifttoshift's Avatar
I have only done one. It worked fine for that car, it was a cruiser of a 61 vette.
A pressure switch failed in the first 500 miles and ABS just sent out a new one.
Donny
Old 11-30-2018, 07:51 AM
Turbo6inKY Turbo6inKY is offline
Thanks,
Dave
Raid the parts bin for a braking system from an EV? They all have full hydraulic ABS systems with an electric booster pump.
Andrew Scott
1987 Buick Grand National
Web Log
Instagram
Youtube
Old 11-30-2018, 10:47 AM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
We've used one of the ABS electric units before and had issues with some seals leaking. The bigger problem though, was that the car we used the kit on had a conventional 9" with fixed calipers, and there was enough knock back and deflection that you would use up all of the vacuum assist pumping the pedal back up, and you'd essentially be stuck with a 1-5/16" manual master cylinder that couldn't stop the car.
http://bestofshowcoachworks.com
(760)480.0227
1969 Camaro - always broken GM Design winner
1965 Mustang - widebody fastback
2006 Coyote swapped "Rental Car"
Up next:
Steve's GT40
Old 11-30-2018, 12:55 PM
Smile Thanks - I greatly appreciate the feed back.
I really appreciate the feed back.
Have a great holiday season!
Dave
Tags
brakes, electric booster
