Old 08-27-2006, 07:04 PM
clill's Avatar
clill clill is offline
Default C.W.I. IRS for 1st Gen Camaros
I saw it at Pleasanton. It is a real bolt in setup that takes maybe one hour to install after you have removed the old setup. No welding, cutting or drilling. No framework modifications. 9" Ford rear. Fully adjustable, toe , camber and ride height. I sent Scott pics to post. http://www.cwiinc.com/ I'm no suspension expert but it looks similar to a Jag IRS.
Old 08-27-2006, 07:23 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Pics:
My LS7 69 Camaro
Old 08-27-2006, 07:24 PM
XcYZ's Avatar
My LS7 69 Camaro
Old 08-27-2006, 07:25 PM
XcYZ's Avatar
My LS7 69 Camaro
Old 08-27-2006, 07:31 PM
camcojb camcojb is offline
Concours West has been doing the IRS setups for street rods and Cobra's for many years. Looks like a cool setup and the bolt in factor should allow them to sell some, depending on price.
Old 08-27-2006, 07:36 PM
clill's Avatar
He said they can also move the outer structure inward for those that want to mini tub. It really does look like you could bolt it in in about a hour.
Old 08-28-2006, 02:39 AM
71Nova 71Nova is offline
It looks very similar to a Kugel Komponents rear set up. Kugel's brakes are inboard to lower unsprung weight. These have the the disk at the hub. I wonder how they would compare to the quadra link or the Lateral dyn 3 link.
Link http://www.kugelkomponents.com/produ...uspension.html
Old 08-28-2006, 04:35 AM
Hooligan's Avatar
Hooligan Hooligan is offline
I'm no expert either, but I always thought that Jag rear ends had inboard disc brakes, like the kugel setup.
Old 08-28-2006, 07:03 AM
clill's Avatar
They said they can do either inboard or outboard but with inboards you have a hard time running the exhaust out over the halfshaft.
Old 08-28-2006, 07:10 AM
Payton King's Avatar
Default Cool looking piece
any idea on price, hp/torque rating? Not so much from the gear set since you stated it was a 9 inch, but on the half shafts and the rest of the IRS
