Old 01-13-2019, 05:15 PM
jcal87's Avatar
jcal87 jcal87 is offline
Default Seized brakes?
Tried to take the car out tonight for a quick spin and right off the bat the car felt like I was dragging something. So much so I got out to make sure I didn’t leave a tire chalked. Took it around the block and barely made it back in the garage. Had a white smoke coming out from under car.
I drove the car about a week ago and it ran perfectly fine. I did run it hard though. I took a video of the white smoke coming out from the rear but it will not allow me to post it. Anyone have any ideas?
1968 Camaro Blue
1968 Camaro SS (Sold)
Texas A&M Alumni
Old 01-13-2019, 09:39 PM
cluxford cluxford is offline
Vac booster or Hydroboost?
I had a similar problem a few years ago with a vac booster. I had to drive home about 6 miles with rear drums smoking...had to get drums machined as they went out of round and new shoes.
It was the small disc ( think they call it a reaction disc) in the booster and the booster was essentially "staying on". Never had it before so didn't know what the issue was, but could have pulled the vac tube to the booster and it would have been fine (albeit manual brakes till I got home).
68 Camaro 632 BBC 800+ HP Project (600Kw)
61 Buick Lesabre Bubbletop (daily driver)......miles of smiles
Old 01-14-2019, 09:24 AM
71RS/SS396's Avatar
Could be a collapsed flexible brake line or I had a manual proportioning valve fail once that did the same thing.
Old 01-24-2019, 06:17 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
Are you sure the park brake is not stuck engaged?
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
The Following User Says Thank You to TheJDMan For This Useful Post:
AB69Z (01-30-2019)
Old 02-17-2019, 09:05 AM
Build-It-Break-it's Avatar
My wife's 65 mustang use to do the same thing. Id drive it one day and it be fine. Drive it another day and one of the calipers would lock up. It would only lock up the rear brakes. I investigated it and started with the proportioning valve since only the rear brakes were locking up. I took up off and apart and found what looked like a broken piece in the valve.
From my research online the proportioning valves have a safety feature in them so that if they fail they lock up rear brakes so you can stop safely ( not on the freeway away 75mph)??
I changed the valve to a wilwood one instead of the what im assuming was Chinese, bled the brakes and problem solved.
Not sure what brake system you have tho.
Keep us posted on what you find.
Ahmad B
Old 08-21-2019, 02:32 PM
Loyaltyisking Loyaltyisking is offline
so many possibilities.. Ahh the suspense! LOL
Old 09-19-2019, 10:16 AM
Panteracer's Avatar
Panteracer Panteracer is offline
Default Seized up brakes
My Pantera had the front brakes lock up two years back
Installed a new Master then and good until Monterey weekend last month
and the same thing happened.. Ordered a new AC Delco master
but still made in China... decided to take the old and new to
Power Brake Exchange in San Jose and have them figure out what
is the issue
Seals were swelling up so it would not return.. so he asks me what type of Brake fluid I am using... Was running Castrol dot 4 lma until about 6 years back when I Switched to Motul 600 motorcycle fluid for the high heat
My Viper buddy was running it in his car so decided to change
I guess it is what has caused the swelling. Had power brake exchange change out the seals in both the new and old master to a Raybestos usa made seal that he gets out of Texas
Hopefully my brake issues every two years will go away
Bob
Old 09-20-2019, 05:38 PM
GEARBOXGARAGE's Avatar
GEARBOXGARAGE GEARBOXGARAGE is offline
Bob brings up a good point also. Inter-mixing different grades (DOT3 to DOT4, etc.) could possibly cause swelling of seals and other rubber parts in the system and cause lock-up if you don't get the first fluid completely bled out when switching grades.
Hope you get it sorted.
-MIKE
Old 09-21-2019, 09:39 AM
NOT A TA's Avatar
NOT A TA NOT A TA is offline
I'll add that another thing that can cause the issue is an adjustable clevis rod that isn't locked tight.
John Paige
70 Firebird Esprit, 400 TA clone type "The 14 car"
lab-14.com
