Old 03-15-2019, 01:01 PM
ChevyThunder's Avatar
ChevyThunder ChevyThunder is offline
Default TKO 600 issues. Who to send to
I put a Keisler Perfect Fit TKO 600 in my 69 Camaro around 2005. From day one the second to third shift is not good. Apparently a known defect around that time.
I am in Nor Cal and my question is instead of sending my trans all the way to Liberty Gear in Michigan is there someone closer to me in California ? Plus Liberty is three months out.
Thank you in advance for any suggestions
Burn Rubber Not Your Soul
A bunch of Camaro's
Porsche 962
Porsche 935
Porsche IROC series RSR (Fittipaldi)
Old 03-15-2019, 01:33 PM
79Bird's Avatar
79Bird 79Bird is offline
Not any closer, but if you are shipping anyway try Hanlon Motorsports
http://www.hanlonmotorsports.com/
Old 03-20-2019, 11:43 AM
Josh@Ridetech's Avatar
Josh@Ridetech Josh@Ridetech is offline
I vote for D&D Performance on that one. They did wonders on my TKO600. However, they're in Michigan as well...
Old 04-12-2019, 08:22 AM
DT69Cam DT69Cam is offline
How is your Reverse gear ?? Mine can be a bitch.
69 Camaro Convertible (LS3/TKO in the works)
Old 04-12-2019, 10:03 AM
Bite the bullet and go Magnum. I upgraded my 600 with carbon fiber synchros and shifter and I still hated it. I was spinning a big block 6800 with an aluminum flywheel in full disclosure.
Old 04-15-2019, 03:37 PM
NAPA 68 NAPA 68 is offline
One of my friends sent his to Liberty. I must say, I never thought a TKO600 could shift that nice.......up or down.
No more 2-3 issues at WFO either. Money well spent
Tim
Old 04-23-2019, 02:27 PM
Why not just Sell it and switch to a T56....
I had a 600 —- worst shifting “truck” transmission ever...
By the time you crate it and ship it - and pay freight back and pay for the rebuild and the better parts.... and the downtime.....
The Following User Says Thank You to GregWeld For This Useful Post:
Vegas69 (04-23-2019)
Old 04-23-2019, 03:22 PM
68454RS's Avatar
68454RS 68454RS is offline
I'm pretty sure Craig Wright does some TKO stuff, and he's in Bakersfield. Might give him a call and see http://www.wrightconnection.net/home.html
also on facebook https://www.facebook.com/wrightconnection.net/
Old 05-13-2019, 09:15 PM
gnx7's Avatar
gnx7 gnx7 is offline
As stated sell that POS and buy a T56 Magnum.... the smoothness in shift quality cannot even be compared.... I'm shifting a 100% stock T56 Magnum at 7800rpm making 1200rwhp+ in my LS9 turbo RX-7 1/2 mile car. I put them in all the conversions I do. TKO600 is dinosaur technology.
They are putting them behind 2JZ builds making 1600rwhp+ and shifting at 10,000rpm running mid 7's@200mph+
https://www.youtube.com/watch?v=G_D-IXfRzGg
T56 Magnum has provisions for mechanical and VSS speedos, multiple shifter locations, beefy 31 spline output shaft, and all the internals are made from a better grade steel than the older T56's '93-06 style....
The Following User Says Thank You to gnx7 For This Useful Post:
GregWeld (05-14-2019)
Old 06-25-2019, 04:49 PM
jarhead's Avatar
jarhead jarhead is offline
Thunder, what did you decide?
I have a 600 and it's not in the cards to change it, going to live with it...
joe
Semper Fi
My 68 Torino
