Old 10-04-2019, 04:41 AM
paulk68 paulk68 is offline
Default Enlarging Rotor center holw
So my baer rotor won't fit over the moser axle register. has anyone opened the rotor center hole before? gonna find a machine shop to do this for me. but just wanted to see if anyone had run into this issue before.
Old 10-04-2019, 06:34 AM
Oleyellar Oleyellar is offline
Default Been there done that
Yes, I had to open the hole for my Moser axles. I also had some issues with the park brake drum inside the rotor that I had to fix. Different rotor than yours, single piece but it came from Baer with the SS4 rear kit.
Old 10-04-2019, 06:52 AM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
Haven't seen it in a while but it's happened to us before;
Pretty cheap to have a machine shop open it up a bit!
-Dale
SchwartzPerformance
Where classic style meets modern technology.
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 10-04-2019, 07:39 AM
I had an issue with the rotor not fitting over the parking brake. Baer walked me through how to reset the pin inside to free up the shoe.
Old 10-04-2019, 07:40 AM
-Dale
Dale would it be easier to open the rotor or have the axle register turned down?
Old 10-04-2019, 10:47 PM
JKnight JKnight is offline
I’d mess with the rotors before the axles. Your next set of rotors may fit fine but if you turn down the axle....
Old 10-05-2019, 03:39 AM
Thanks guys Looks like it was built for willwood rear brakes when it should have been Baer. So I may open the rotor up to the 3.060 hub. just want to check with baer that it will not affect the hub at all.
Old 03-03-2020, 03:18 PM
linenoise linenoise is offline
Default Baer brakes
got same issue. just got new brakes in. DSE rear end with moser axles in it. Bought the baer brakes with drum in middle. The rotors are too small for the axle center. Got to do a machine run on them.
Old 03-04-2020, 06:22 AM
572Camaro's Avatar
572Camaro 572Camaro is offline
I dealt with this same issue once back about 10 years ago.
Baer rotors, Moser axles.
After a couple phone calls, Rick Elam from Baer had me ship my axles to Baer Brakes to machine the axles instead of the rotors.
Why?
Because my axle registers were different diameters by about .010”.
Rick assured me that he would have them machined so future rotors would all fit (from Baer of course).
I honestly don’t know what is best, just wanted to share..,
The Following User Says Thank You to 572Camaro For This Useful Post:
camcojb (03-04-2020)
