Old 12-03-2019, 11:28 AM
ADY's Avatar
ADY ADY is offline
Default Sound level of exhaust dumping before axle vs. rear
Currently have my exhaust dumping out before the axles and really looking for something a little quieter. Does is make a difference in sound level if you extend the exhaust to the rear of car? I installed QTP mufflers (http://www.quicktimeperformance.com/screamer/) hoping I'd get a quiet muffler that I could open up for more sound, so I've got too much invested to swap out for another muffler at this point.
thanks,
-Adam
-Adam
1968 Camaro SS
Old 12-03-2019, 04:55 PM
So you're currently running the Screamer mufflers with dumps and even in quiet mode it's too loud? Just making sure I understand you correctly.
In general, yes, running the exhaust out the back versus dumps will make things quieter inside with no other change.
Old 12-04-2019, 08:36 AM
ADY's Avatar
ADY ADY is offline
Correct, with the cut-outs fully closed its too loud for my taste. Hard to have a conversation with my kids in the back seat.
Thanks for the feedback, I'll try extending to the rear and see if it helps.
-Adam
1968 Camaro SS
Old 12-04-2019, 09:04 AM
CamaroAJ's Avatar
CamaroAJ CamaroAJ is offline
You could also add resonators to the pipes that you take all the way back to kill even more noise and drone.
Instagram- camaroaj
The Following User Says Thank You to CamaroAJ For This Useful Post:
ADY (12-04-2019)
Old 12-05-2019, 07:05 PM
x2 or high flow catalytic converters up front. Magnaflow and others make universal performance cats that won't take away power. They will help control the noise though. Good luck!
Old 12-05-2019, 07:17 PM
jmac jmac is offline
Are resonators more effective before or after the muffler?
I've seen it both ways, just wondering if there's a benefit of doing it one way or another.
Old 12-09-2019, 11:02 AM
CamaroAJ's Avatar
I think its more about packaging on some. The Trailblazer SS had it after the muffler. The butterfly valves to control drone on the GM trucks are after the muffler, but the Vette (if equipped with them, some aren't) are before the mufflers.
Instagram- camaroaj
Old 12-09-2019, 03:46 PM
Flash68's Avatar
Flash68 Flash68 is offline
Tailpipes all the way to the back will definitely reduce the in cabin noise. I prefer the dumps because I don't care to talk to my kids.
But I get it.... do the tail pipes... then if still loud, do a larger case muffler setup.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
The Following User Says Thank You to Flash68 For This Useful Post:
ADY (12-11-2019)
Old 12-09-2019, 07:12 PM
Zspoiler's Avatar
Zspoiler Zspoiler is offline
Use a balance tube as well.
The Following User Says Thank You to Zspoiler For This Useful Post:
ADY (12-11-2019)
Old 12-11-2019, 11:09 AM
ADY's Avatar
ADY ADY is offline
thanks, setting up a trip out to West Coast Muffler in Concord once we have a dry weekend.
-Adam
1968 Camaro SS
