Old 04-04-2020, 06:55 AM
Default Protecting door Jams, rockers from rust.
Not PT related but hoping its relevant. I have a GMC 1500 and live in the north east where roads get treated with salt. Rust is a problem ..
I was planning to trade in my 2017 soon but now I am thinking I might have to keep it indefinitely.
Curious if anyone has a product recommendation .. ceramic coating or corrosion product. that might actually work.. door jams and rockers seem to be a common rust spot on pickups..
Old 04-04-2020, 07:03 AM
slimjim's Avatar
slimjim slimjim is offline
Do you mean they just rust there in general or they typically rust from the inside? I'm not following 100% but Eastwood make this internal frame rust encapsulator setup that's cheap and looks easy to use for better protection.
NC
streamline 68 camaro
Build Thread here
Old 04-04-2020, 07:28 AM
What I mean is the area traps slush and ice.. which are like. giant salt rocks.. at sit on the truck... and the door jams.. ice and salt sit in that area..
Old 04-04-2020, 07:56 AM
slimjim's Avatar
Oh I see, my idea won't work then, not quite sure what will
NC
Build Thread here
Old 04-04-2020, 10:26 AM
Both 3m and wirth make a cavity wax . It's not an oil that makes all dirt n crap stick to it, or in the summer heat the oil drips everywhere. It's a spray wax that drys ,leaves a film ... Google it
Old 04-12-2020, 11:01 PM
AMSOILGUY's Avatar
AMSOILGUY AMSOILGUY is offline
Default Your solution
You can order this and get it delivered to your door. You have until 4/30 to Use Promo Code : FREESHIP and receive free shipping on orders of 50 dollars. Please use this link and AMSOIL will give me credit for your order https://www.amsoil.com/?zo=1856266
Made with special rust and corrosion inhibitors. Excellent on metal surfaces, leaves a long-lasting protective coating. Protects against the effects of salt, moisture & chemical corrosion. Works as an undercoat, leaving a wax-like amber film.
[email protected]
www.jacobehlers.com
The Following User Says Thank You to AMSOILGUY For This Useful Post:
camcojb (04-13-2020)
Old 04-19-2020, 04:53 AM
is it for painted surfaces or raw ?
Old 04-19-2020, 05:49 AM
AMSOILGUY's Avatar
It will leave the film on both. The paint has the metal sealed but if you have unprotected metal then this will protect the exposed metal.
[email protected]
www.jacobehlers.com
