Old 04-22-2020, 08:01 PM
lsuguy's Avatar
lsuguy lsuguy is offline
Default Brake Clamping Force Help
So there was a slight mishap with my Forgeline wheels that due to fitment has limited me to utilizing Wilwood Forged Narrow Super Lite Calipers (6 Piston Front, 4 Piston Rear) and 14" rotors. My original plan was to run Baer 6P calipers on all 4 corners but, those are no longer an option.
So in short my brake system will consist of:
Hydratech Hyrdoboost
Baer 1-1/8 Remaster Master Cylinder
Wilwood Forged Narrow Superlite 6P 14" Front
Wilwood Forged Narrow Superlite 4P 14" Rear
The wilwood calipers are available in a range of piston areas so my question is what is everyone's thoughts on my setup and if I need to tweak anything.
I have tried to find a calculator to help with braking force to see if I am where I need to be, but the boost unit is making it hard for me to determine what I need to do.
Old 04-23-2020, 05:32 AM
dontlifttoshift's Avatar
I didn't do any math but can tell you from experience that with a proper hydroboost setup the 4.04" calipers will be fine in the front.......and I would be tempted to run the 2.46" in the rears.
Tell us more about your cars intended use and tire brand and sizes.
Donny
Old 04-23-2020, 09:52 AM
lsuguy's Avatar
Aggressively driven street car. I doubt it will see the track.
18x9.5 up front
19x12 in rear
Using Michelin Pilot Super Sport 275 front, 325 rear
Old 03-12-2021, 03:55 PM
65 Drop Top 65 Drop Top is offline
From my experience with Wilwood 4.04” and 2.46” calipers and manual brakes, I can pretty much guarantee that a similar brake set up with hydroboost would be pretty insane.
