Old 06-08-2020, 09:20 PM
bergers59 bergers59 is offline
Default 335 front tires possible?
Hey everyone,
Been refreshing myself on suspension for my 67 camaro recently. I've been trying to figure what subframe I want to run; likely Speedway G-comp Unser or TCI. Anyways it seems as though a 315 is very doable with just rolling the fender lips. Running 335 square is obviously advantageous over a 315 front/335 rear setup. Does anyone out there run a 335 front?
Old 06-09-2020, 06:14 AM
dontlifttoshift's Avatar
Of the people I know of that have done it, at least half of them have gone back to 315. The ones that are happy with the 335 have a lot more going underneath than an off the shelf aftermarket subframe.
Something else to consider. There is exactly one 335 out there that is 200TW and legal to run for most of these events.
Donny
Old 06-09-2020, 06:17 AM
patriot68 patriot68 is offline
Speedtech Xtreme sub
1968 Camaro, LS1/T56,martz chassis,19x10/18x8 Budniks,245/45/18,295/35/19 {Sold}
http://www.fquick.com/patriot68
1971 Firebird - Speedtech Extreme Subframe/Torque Arm, LS3/4L80E, 19x12/18x10 Budniks
Old 06-09-2020, 08:07 AM
Why do you want a 335? Where will the car operate the majority of the time?
Old 06-11-2020, 12:09 PM
That's a good point, for some reason I thought NT555s went to 335 as well, I guess not. What else would be going on in terms of suspension other than an aftermarket subframe and fender tweaking/flaring? It's hard to imagine anyone would develop a better suspension than what a lot have companies have to offer.
Hard to say, likely 50/50 street and track.
Old 06-11-2020, 12:12 PM
I do like the ATS spindles they use. On their website it says they fit 315s like the other subframes I mentioned, unless its 315 without fender modifications and 335 squeezed with fender modifications?
Old 06-11-2020, 12:19 PM
I think the biggest deterrent for going 335 would be where the difference in tire is "added". As in if the centerline/contact patch doesn't remain in the same location, the scrub radius will likely be moved in an undesirable direction.
Old 06-11-2020, 06:30 PM
Panteracer's Avatar
Panteracer Panteracer is offline
Default 335 tire
My experience is the Bridgestone re-71re tires are the best
Tire for a 200 rated tire you can buy. Largest tire in an 18"
Tire is the 285. My option better than a 315 other brand tire
I have run these with a dot road race tire zero wear rating out back and seemed like a zero rated dot tire in front
My 2 cents
Bob Benson
Old 06-20-2020, 04:16 PM
My 2 cents
Bob Benson
There's a lot of factors, but you may be right. I think I;m going to stick with a 315 square setup, I don't like the idea of being stuck to one brand/model of tire. Rt660s seem promising
