Old 05-24-2021, 08:21 PM
CHJNCSU CHJNCSU is offline
Default What is the best AutoX Track Front Suspension 1st Gen FCar
I am building a 1968 Camaro for CAM T, GoodGuys and Optimia events. The car will see limited street use. 98% Track 2% street. What is the best complete front suspension/subframe to use?
Thank you for your comments!
Old 05-25-2021, 09:08 AM
572Camaro's Avatar
572Camaro 572Camaro is offline
I don’t know all options out there.
Detroit Speed makes a great subframe package which is top of the line.
Is this an LS application?
Old 05-25-2021, 09:21 AM
The engine is a NA LS7 being built by one of the top builders
Old 04-12-2023, 10:07 AM
syborg tt's Avatar
The first question is what is your budget and time line as swapping a subframe under takes time.
DSE, RideTech, QA1 and SpeedTech all sell bolt on kits which is more then 95% of most people's need or can actually use to it's potential. Personal I would stick with a true bolt on kit as you will be able to do 90% of the kits in a week or less.
marty-mj
The Following User Says Thank You to syborg tt For This Useful Post:
130fe (04-12-2023)
Old 04-18-2023, 04:54 AM
srode1 srode1 is offline
If you are building a dedicated car from scratch and really want top performance for autoX Speed Tech Extreme with the torque arm is a great choice, room for really big tires up front. DSE with their 4 link would be my second choice, a bit less room for tires up front but a great package. That's my opinion, worth about $0.25
Old 04-18-2023, 06:13 AM
Thank you for the advice!
Old 07-28-2023, 10:03 PM
David Pozzi's Avatar
You definitely need an aftermarket subframe on a First Gen Camaro. You can't fit a decent size front tire under stock fenders with a factory subframe. DSE & Speed Tech, are good. I'm using the Art Morrison and find it easy to tune/work around. The DSE rear suspension on a first gen uses short shocks so there's not much room to lower the rear below their design height. Their second gen setup is better.
http://www.PozziRacing.com
The Following User Says Thank You to David Pozzi For This Useful Post:
camcojb (07-29-2023)
