Old 03-31-2022, 04:02 AM
paulk68 paulk68 is offline
Default wiring for fuel pump/sender
Hey All, looking to add a weatherpack quick connector to the wiring coming from my tanks inc fuel pump and sending unit. Can you recommend the correct gauge wire I should using for each? make to make it like a foot long or so.
Old 03-31-2022, 09:05 AM
camcojb camcojb is offline
Ultimately wire size goes by amp load. Looks like Tanks calls for #12 wire to the pump. The sender wires are probably smaller, I would just match the size they have coming off the sensor. A step bigger is fine but I don't go smaller.
https://www.tanksinc.com/pdf/RLYFP_Instructions.pdf
paulk68 (04-01-2022)
Old 04-01-2022, 02:31 AM
Awesome thank you!
The Following User Says Thank You to paulk68 For This Useful Post:
camcojb (04-01-2022)
Old 04-30-2023, 02:15 PM
Y-TRY Y-TRY is offline
I’ve been overthinking the best style of connector to use for the sending unit. What have you guys done?
