Old 05-17-2022, 05:25 PM
DRJDVM's '69's Avatar
Default TO bearing issue
I swear to God my car is cursed....and people wonder why it's taken me so long to build my Cuda. I've had the transmission in/out going on 4 times now
The latest issue.... took the car to a local car show. Long line to get in so it was stop and go for a good 1/3 mile. By the time I got in, there was smoke under the car and it smelled like clutch.... bad..... couldn't really find the source but I thought I had overheated the clutch with stop and go.... its only got about 125 miles on a new McLeod twin disk. Got it parked and just hung out for the day. On leaving everything felt fine.... no more smoke, seemed to drive ok too.
Got the car home and next day got in up in air and there was fluid all over the bellhousing and the clutch master was down a good 3/4 inch. Looks like the TO puked fluid out the bell and the header, thus creating the smoke and smell.
So somehow I caused the TO to puke fluid... all I can think of is that I either didn't set the clutch pedal stop right and over extended the pedal a bunch of times in the stop and go traffic and blew the seal..... or I screwed up the TO to clutch air gap and over extended the bearing in some way.....
I must have checked both of those like 100 times.... but thats the only things I can think of to make a TO puke fluid
So.... all apart AGAIN.... TO bearing doesn't look jacked up ....Craig at Bowler had me send it back so they can inspect and rebuild
Clutch has some hot spots on the pressure plate so that's on the way back to McLeod to see if I ruined my $800 new clutch or it can be salvaged. Figured the hot spots are from the clutch slipping when the TO gave up and then wasn't fully releasing the disk
Any other ideas on how a TO would puke fluid? The lines are fine... so signs it rubbed a hole etc, so it must have come from the piston seal
This car has fought me this entire build.....
Old 05-17-2022, 07:20 PM
camcojb camcojb is offline
A friend had a similar issue, and it turned out to be the T/O bearing fluid line was close to the headers, and was overheating the fluid. He re-routed the line and never had the issue again.
ADY (05-17-2022)
Old 05-17-2022, 10:15 PM
My lines are pretty far away from any heat source. I have them zip tied pretty good but I'll keep that in mind when I put it all back together to be sure
Old 05-20-2022, 08:41 AM
It seems like it could be heat related due to the heak soak you likely experienced. If it was me, I'd consider having another set of eyes look things over before it goes back together. You have to be missing something.
Old 05-20-2022, 10:20 PM
TO bearing was checked by Bowler and nothing obvious on the seal. Rebuilt it anyway since I'm 99% sure the fluid puked from there
McLeod looked at clutch and the disks were fried, and mid plate warped. I have a feeling that happened after the TO died on me and the disk wasn't fully releasing when the clutch was depressed, so it was slipping like crazy and torched the disk. The clutch is rebuilt and on the way back to me
Its got to be the throw on the pedal.....
Old 05-20-2022, 11:14 PM
Good thought.
Old 05-23-2022, 09:58 PM
Sent the TO to Bowler- nothing obvious but rebuilt it anyway...
Clutch to McLeod..... disks were torched and the mid plate was heated and warped. They rebuilt it..... and all under warranty, despite this likely being something on my end... shout to McLeod for great customer support
Got it all back together... spending a ton of time of getting the TO air gap right at .125 per Tilton.
So it all back together.... bled the hell out of the whole system, both power bleeder and the old fashion way. And I still cant get the clutch to release trying to set the stop.
Plugged the feed line off the slave and the pedal is like a rock....so I don't think its the slave.
The pedal feels pretty decent and I can see it move the TO bearing forward. I just don't think its generating enough pressure to push the clutch finger in
All I can think of is the pedal throw. Its got an adjustable link, so I can thread it farther/less onto the slave rod and then adjust the how far the link its into the center piece to start, then tweak the pedal height.
Trying wrap my head around the physics to maximize the throw. The slave rod is essentially static, while I can make the heim joint that attaches to the pedal be in/or more on the center piece to start. Once its together I can rotate the center section to fine tune the pedal height.
If its not the pedal travel, I'm stumped on what else to troubleshoot at this stage
Old 05-24-2022, 07:18 AM
dontlifttoshift's Avatar
What is the total travel on the throw out bearing?
With everything installed, what is the distance from the clutch fingers to fully compressed on the throw out bearing. In other words, where in the total travel does the bearing sit at idle?
How much bearing travel does it take to fully release the clutch?
What master cylinder are you using and how is it mounted? What is the bore size?
Donny
Old 05-24-2022, 07:19 AM
...double post
Donny
Old 05-24-2022, 09:17 AM
Its a Tilton 6000 series hydraulic TO bearing
Per the Tilton instructions I set the air gap at 0.125.... I can see in the bell the TO is slightly pushed out from fully compressed... I can reach in and full push it back in. When I depress the clutch you can see the TO extend out
T75-750U 3/4 bore compact master cylinder, per my purchase invoice...
RST twin disk clutch
Based on the Tilton sheet, with lever style clutch and a 3/4 bore slave, the master cylinder stroke is supposed to be 1.4 inches.... with a diagram type clutch its 1.1 inches
All the stuff worked before I had the blow out. The only thing that may be different is the clutch rod length. The upper heim didn't have a jam nut and it didnt fee like it had much thread engage so it had a bit of wobble to it, so I pulled it all out, and screwed the heim in father then reattached everything and then adjust the pedal height. But all that should do is move the center adjustment piece up and down on the threads... it shouldn't effect the throw on the slave, unless I'm not thinking about this right
It all worked before.... so something is different now...
