Old 07-30-2022, 11:32 PM
Miikeremains Miikeremains is offline
Default 68 Camaro - front susp. Drop Spindles?
Tried searching but couldnt find my answers.. Sorry
Im in the process of getting my DSE minitubs done and Ridetech 4-link with Shockwave is on the way.
Im looking to order new wheels and tires for this setup and have some questions for the front end - so they match.
What is the biggest 18 wheel and tire i can fit without rubbing the fenders? Frame rubbing won't bother me.
Are drop spindles generally used or is front end height set with stock size spindles and coilovers? I dont think i can use the shockwave on the front with my stock control arms..
Thanks guys
Old 06-07-2023, 09:53 PM
David Pozzi's Avatar
I highly, highly, recommend getting an aftermarket front subframe for a first gen Camaro. Especially a 67 or 68. They don't have much room for wide tires up front and you sacrifice handling. A 255x18 is about the limit & even that will rub at full lock.
With rear minitubs you can probably run a 315 rear tire and probably even a 335. But you will have terrible terrible understeer due to lack of front tire width.
http://www.PozziRacing.com
The Following 2 Users Say Thank You to David Pozzi For This Useful Post:
camcojb (06-07-2023), colorado80439 (06-08-2023)
