Old 09-25-2006, 05:37 AM
tomspo04 tomspo04 is offline
Default Front is sitting WAY too high!
Help, anyone? I set my second gen Camaro on the ground and it's sitting 2-3 inches too high. Everything is new. Upper CA's are Hidts, Lower CA's are GW, springs are Hotchkis (small block). The engine is in (ZZ502, Aluminum heads) all accessories are mounted. I originally had the Hotchkis BB springs but swapped them out for the SB...it's still too high! Any suggestions?
1970 SS (L-34) Protouring Camaro, 502 RJ, TKO 600 W/aluminum drive shaft, 3.42 rear, C5 ZO6 brakes front & rear, Hotchkis TVS, Boze Mesh; (17X9.5 275-40) & (17X11 315-35), Rick SS fuel tank W/pump, March Ultra serpentine setup, Hiedts/GW UCA's & LCA's, MagnaFlo 3" SS exhaust w'Xpipe.
Old 09-25-2006, 07:37 AM
Tony@AirRideTech Tony@AirRideTech is offline
Supporting Vendor
First thing that comes to mind would be that they sent you the incorrect springs. A lot of spring manufacturers will put a part number on them, find the part number and look it up to see what they sent you...... if the part number comes out as being correct. It may simply be the wrong spring rate or cut height. The other thing to check is to make sure you have not tightened anything up underneath to the point of binding up.
Old 09-25-2006, 08:14 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Are the springs seated correctly? Did you torque everything down when the car was in the air?
My LS7 69 Camaro
Old 09-25-2006, 10:40 AM
Default Springs are indexed proplerly
Yes...they're in correctly. I know the LCAs are free moving...I don't think there's a problem with the uppers but I'll double check tonight.
Old 10-07-2006, 01:21 AM
71Nova 71Nova is offline
A friend of mine has a 68 Camaro that was to high in the front. He swore that he indexed the springs corectly but it ended up to be the problem.
