Old 09-28-2006, 08:15 AM
Payton King's Avatar
Default Jimmy Johnson's rear suspension design
Ok,
I am not claiming to be any sort of expert on suspension design. I am just explaining this as it was explained to me. Apparently in the 60's when Chrysler was into factory sponsored drag racing they were running a class, I think Super Stock, and the rules stated that if the car was produced with a rear leaf spring suspension it must be run. They were having a hard time getting the leafs to hook so they came up with this idea to get around the rules.
Basically the leafs act as the track bar, spring (duh) and lower link. The rear is not mounted to the spring by a conventional perch but instead by a swivel link(my term). The upper link is just like normal.
This type of suspension was also used on an Austin Healy 3000 in the 60's. Jim Pettigrew use to have one and dropped a small block in it. He stated that rear worked great and it would really hook and drive great.
So with all of that said, lets hear some opinions. Pros and cons.
Jim would be more that happy to make these for anyone as a low cost alternative to what is out there now.
Old 09-28-2006, 09:44 AM
evilzee28 evilzee28 is offline
Had a similar set up on my '55 Chevy with a "floating" axle like that. The car ran arrow straight a 10.57 @135mph, with no lateral movement at all. Nice easy to make set up.
Old 09-28-2006, 09:50 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Cool, thanks for sharing, Payton.
My LS7 69 Camaro
Old 09-28-2006, 12:51 PM
Default I posted this over at pro-touring as well
and the dude at AME thought that there was going to be roll bind due to the short upper link. I am no susupension guru, but I thought the problem with 4 link and tri-bar set up was the same roll bind as this set up. What I saw from the times at the run through the hills...all of them performed about the same, including the leaf cars.
Is this a therory thing on a computer model at the absolute limit of suspension travel or is this a problem on the street and track days?
Old 09-29-2006, 06:19 AM
that is a very interesting set up.
1/12th scale 1969 Sunset Orange Metallic Camaro Pro Touring Style>>
Progress Thread
Artwork Page
Old 09-29-2006, 09:48 AM
astroracer astroracer is offline
I have done a bit of sketching and thinking about this and have come to the conclusion that the "Leaf Link" rear suspension will have much less roll bind then your typical 3 or 4 link, coil over suspension.
I loaded a few Power Point drawings into my Fotki site here:
http://public.fotki.com/astroracer/s...ulation_study/
I didn't do a lot of labeling but I think you will get the picture. Remember the diagrams are hand drawn so take them as they are...
The typical 4 link has a ton of freedom in a straight up and down articulation. Roll bind comes into play when you induce jounce (bump) or rebound (droop) into the suspension in a non-planer direction (say, RH wheel up 2" and LH wheel down 2"). The suspension will want to rotate around the lower links. A perfect "rotation" would have ALL of the 4 bar pick-up points on the chassis and axle in the same rotational axis. This can't happen of course so the links end up working against themselves. This is multiplied when you throw in the panhard bar which is on ANOTHER rotational axis, actually controlling the lateral movement of the housing and inducing even more bind...
The "Leaf Link" (for lack of a better term?) will control roll with the springs, it is inherent to the design. You can see in the last diagram there is much less induced roll with the springs controlling both lateral movement and rotational deviations. The springs also "work together" because they are tied together through the housing. The spring/housing mounts create a hard line of reaction (through the housing) between the two springs that a 4 link does not see.This forces the housing to rotate around the front and rear spring bushings of BOTH springs. This requirement also centers the rotation "point" somewhere under the middle of the housing. The amount of roll can be controlled with the type of bushings being used. Controlling body roll with good shocks and sway bars will also help reduce roll bind with this suspension.
On a race course, with controlled variables, the induced roll bind will probably be negligible with minimum suspension movement.
I am just thinking out loud here so jump in with ANY comments or thoughts you may have.
Mark
"Bad Ast" Astro Van Pro-Touring Project.... Heat, beat, file to fit, paint to match...
Old 10-02-2006, 06:35 AM
Default Thanks for your time on this one
Just looking at it in the shop and bouncing the car on jack stands it looked like it will work. Obviously, that is no real test.
Thanks again for your time Mark
Old 10-08-2006, 09:31 PM
David Pozzi's Avatar
I think it will work OK but the concern would be if the upper link were too short compared to the lower link, there might be some binding near the limit of suspension travel due to the links moving out of parallel as they move. If the links were not parallel to start with at normal ride height, then binding is more likely. If the links converge (in side view) towards the front of the car, there will be more anti-squat and more traction, but the binding issue begins to turn the axle housing into a big anti-roll bar.
Since he allready has the four links (if you count the leaf spring) on the car, all he needs to do is add a "real" lower link, coilovers and a panhard bar, and no leafs to save a lot of unsprung weight. I think the car would ride better.
David
http://www.PozziRacing.com
Old 10-09-2006, 07:41 AM
Default Not sure where you are going with this...
Never a 4 link on the car
Old 10-17-2006, 10:06 AM
Marcus SC&C's Avatar
Marcus SC&C Marcus SC&C is offline
FWIW that`s *exactly* the rear suspension configuration designed by Gene Hardig for use in the Studebaker Avanti in 1961. They used it up until around 1987. They actually handle pretty nice considering they`re on a modified Lark chassis designed in the late 50s! So it works,it`s just a question of how well it`ll work in a given application. Mark SC&C
