Old 03-20-2005, 09:13 PM
oldzzy's Avatar
oldzzy oldzzy is offline
Default Help with brake and spindle kit
Hey guys i am new here and new to the car "restomod" thing. I have a 70 Cutlass S that i want switch from pwr drum to disc brakes. I have heard some people say 2" drop spindles are good and others say no so i am confused here. I want the lowered car look. I was on ebay and i just wondered what you guys think of this disc brake kit http://cgi.ebay.com/ebaymotors/ws/e...&category=34199 any help would be great! TIA
Shane
70 Olds W31 clone
http://www.flickr.com/photos/85638053@N00/
Old 03-20-2005, 09:32 PM
jonny51 jonny51 is offline
Page not found,you may want to double check the link.
Old 03-21-2005, 04:45 AM
oldzzy's Avatar
hmmm... try this again... http://cgi.ebay.com/ebaymotors/ws/eB...category=34199
Shane
70 Olds W31 clone
Old 03-21-2005, 05:25 PM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
Shane
you might like this better, looks cooler and custom made at a great price:
http://www.aerospacecomponents.com/pro_street_kits.htm
Good luck dude.
Jim
Old 03-21-2005, 06:25 PM
oldzzy's Avatar
hey thnx Jim, altho that looks cool i will need spindles as well because i have drum brakes right now. I might be wrong here but i was looking at the wilwood site and am i correct in seeing that they have a kit that you can use stock drum spindles?
Shane
70 Olds W31 clone
Old 04-06-2005, 09:14 PM
Marcus SC&C's Avatar
Marcus SC&C Marcus SC&C is offline
You might want to check these out too. http://baer.com/Media/ContentDetails.aspx?ContentID=107 They use 11" rotors (they offer larger ones if you like) but basically the same dual piston aluminum PBR calipers used on C5 Corvettes. This is top shelf stuff and it just flat works and works well. And I`m not just saying that because I`m a Baer dealer. You`re better off lowering the front end with springs. Drop spindles lower the car but leave the suspension arms at the stock angle which is less desirable for good handling. Marcus
Old 04-07-2005, 10:10 PM
USAZR1's Avatar
USAZR1 USAZR1 is offline
I agree. Lowering the car with dropped springs,not spindles,is a better option.
FWIW,the Serious Street kit listed above uses C4 PBR calipers,not C5.
Clint Hooper
Clint's 70 El Camino restomod Sold
Clint's 69 Elky Protourer Sold
Old 04-09-2005, 09:08 PM
Oops,I stand corrected. I haven`t worked with the 11" system before only the 12" and up. Still C4 calipers are a mightly big step up from old single piston iron calipers. Marcus
