Old 03-21-2005, 01:01 PM
MaxHarvard's Avatar
Default Lowering question
I just installed my 2" lowering springs from Hotchkis in my camaro and it appears to be lower, and i measured the body height and it is lower... only by about 1"
Do these things settle in or what?
I know i put them in correctly because when i measured the ride height both sides were equal.
funny thing was, the passenger side tire now has a ton of camber and the driver has next to nothing!! its kinda odd, but i knew i'd need an alignment after putting them in. Is that kind of thing normal?
Old 03-21-2005, 01:24 PM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
I'll probably get Hollered at, Eric, but you'l probably have to cut out 1 and 1/2 coils to get 3 inches of drop. They never seem to settle the full amount.
By the way, the column is 210.00 but they don't have any right now. FYI.
Jim
Old 03-21-2005, 01:33 PM
XcYZ's Avatar
XcYZ XcYZ is offline
I agree with Jim, they will settle, but never as much as you'd like.
My LS7 69 Camaro
Old 03-21-2005, 01:42 PM
MaxHarvard's Avatar
Jim, Scott. thanks for the info, they were only a 2" drop, i didnt want to go too radical.
I hope they settle in a month or two.. i'll keep measuring periodically.
Old 03-22-2005, 06:43 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
I asked Hotchkis about the setteling issue. They said they might settle 1/8". Probably going to have to cut them if you want it lower. I did.
Old 03-22-2005, 07:04 AM
MaxHarvard's Avatar
What about the weird alignment issue i'm having?
One tire has tons of camber, while the other is very negative camber. Like a nascar style car where they all lean to one side.
Old 03-23-2005, 08:21 AM
907rs's Avatar
907rs 907rs is offline
You didn't remove the upper A-arms did you? Do you have a pic?
Bill
