Old 03-23-2005, 11:25 AM
awr68's Avatar
awr68 awr68 is offline
Default Unisteer R&P installed!!
The kit was delivered today so of course I had to dive right in and install it!
The install went very smoothly and the instructions were VERY thurough. This rack weighs way less than the stock gear and gives a lot more clearance for headers. And it actually doesn't hang below the frame's main x-member...very good and tight packaging!! The steering arms bolted right up and clear my 17x8 wheels w/ 5" b.s. no problem. The wheels at full lock come closer to the frame now...therefore allowing for tighter turns!! I also bought the steering shaft kit, but have to wait to get an Ididit column before I install that. It cleared a standard oil pan that came with my crate motor...I'll be ordering a new road race pan soon though. You will see there is plenty of ground clearance and my car is lowered a good 2.5-3"!!
I'm having trouble uploading pics at the moment...but you can see all the before and after shots at my web page here
BTW, the final pic shows the actual ride height with the tie rod level to the ground. Unisteer told me if I have any bump steer issues, due to my car being lowered more than 2", to use Baer's Trackers, they will allow for the needed adjustment...but they honestly didn't foresee any issues.
Hope this helps!!!
Tony
'68 Camaro
