Old 12-08-2006, 08:42 AM
DAWG's Avatar
DAWG DAWG is offline
Default rear upper shock mount questions
im redoing my rear end and installed slide a link traction bars.
my 69 camaro has staggered lower shock mounts and I want to install lower shocks inboard the springs.
passenger lower shockmount will not install other that to the rear as the drivers side. So both lower shock mounts are facing to the rear.
will the comp engineering uppershock mount crossmember work for this?
or will I need to fab a whole new upper shockmount bracket?
pics:
SIT DOWN _SHUT UP_HANG ON
Old 12-08-2006, 10:41 AM
Steve Chryssos's Avatar
The CE crossmember will work, but keep in mind that it will decrease clearance to the top of the rear as well as tailpipe clearance. The DSE crossmember, on the other hand, fits above the framerail height--not between the frame rails. Clearance, in my case, is a real problem because I run 3" drop springs with the CE crossmember.
________________
Steve Chryssos
Ridetech.com
Old 12-09-2006, 07:02 AM
DAWG's Avatar
thks for the help
