Old 04-05-2005, 08:48 AM
BuddyP's Avatar
BuddyP BuddyP is offline
Default Turbo's ??
Old 04-05-2005, 10:24 AM
XcYZ's Avatar
XcYZ XcYZ is offline
The big problem in finding a kit, is one that will fit under the hood. I guess you could run an STS, but after installing the Banks kit, I just don't see how it could be any easier. Not much fab work needed at all.
You could do a blow through carb setup, there's a member here that's doing a single with blow through.
As for the motor, at a bare minimum, you should keep the CR 9.0:1 or lower, forged pistons and a boost specific cam.
These are just my opinions, results may vary. What are your goals?
My LS7 69 Camaro
Old 04-05-2005, 10:56 AM
BuddyP's Avatar
Honestly, I don't have a set goal in mind. In the process of actually starting a restoration right now. Just wanted to plan ahead and figure out what I wanted to do. Right now I had just planned on a Crate 383... but turbo's are pretty cool! Didn't know if it is something that could be somewhat easily upgraded on a motor down the road, which leads to my questioning internal motor componants.
Old 04-05-2005, 05:14 PM
Y-TRY Y-TRY is offline
Kits are hard to find, for sure, and I haven't seen any single-turbo one's at all.
I bought a set of Kook's headers and made little intermediate "wastegate boxes" to locate the turbos better and give a platform for the wastegates. Besides the headers, I designed, and my cousin welded, everything else.
I'm also using a blow-through carb from CarbShop and it seems okay, although I haven't really gotten into FINE tuning it yet. I'm sure that's when the head-scratching starts. EFI would be the way to go but the better stuff is still pretty expensive. Although the carb wasn't cheap it's still less than a quarter of what the EFI would cost.
I built pretty good internals for mine as insurance. Hopefully it will all stay together. I have 220cc heads and 8.1:1 compression, which wouldnt make any since in a non-boosted car. If I had built it like that thinking "maybe I'll do turbos later", the car wouldnt have made any power until I boosted it. So the combo was built around the turbos.
Good luck with the new project.
