Old 04-06-2005, 02:49 PM
rockdogz's Avatar
rockdogz rockdogz is offline
Default Fuel line routing to tank
How did you guys route your fuel (and fuelpump wiring) lines to the rear? I started outside the frame rails at the front of the car, then crossed over to inside the frame rails about halfway through. However, after installing the exhaust, the muffler is 1-2 inches away from the electrical and fuel lines, and I've wrapped the lines in heatshield to protect them. How did you do it?
-Tom
camarorestoration.com
Old 04-06-2005, 05:59 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Tom, I stayed outside the subframe connector until almost to the rear. With the carb setup, I used -8 braided, so it was pretty easy to route. Are you running braided or hardline?
My LS7 69 Camaro
Old 04-06-2005, 06:11 PM
rockdogz's Avatar
Two braided lines for FI, a supply and a return. I thought I was being clever because I was able to thread the lines through an opening in the part of the subframe connectors where they meet up with the leaf spring mounting point. That way, I wouldn't have to cross over the frame rail further towards the rear.
-Tom
Old 04-09-2005, 03:12 AM
Jims78elky's Avatar
Jims78elky Jims78elky is offline
Tom-
I've been snoopin around your site and wanted to ask you about your 502 if you don't mind..Where did you buy it from? And what was the best price you got on it? Also,great job on the camaro the video of its first start up is so cool! Do you think that its possible to run a procharger with a ram502?
Would it be possible? I just would wonder what kind of power that would turn out with that set-up
Thanks,Keep up the great camaro!
