Old 01-30-2007, 02:50 PM
Streetking's Avatar
Streetking Streetking is offline
Default Ok, engine opinions....
So I made the deal on the '71 Camaro. I'm having some work done by the guy that built it before I pick it up. Now I'm thinking, should I keep the 406 in it or put a 502 in it or a hopped up small block? I called the Shafiroff and talked to a guy about their 540/695 hp motor. He went through all the specs and after he told me that it had a big solid roller, I had some second thoughts. I really didn't want a solid roller street car. I need to make a decision in the next few days if I want to get this done. What do you guys think?
SW
Old 01-30-2007, 02:59 PM
Sales@Dutchboys's Avatar
Well I think that you should get a big block
and then sell the 406 to ME!
dutchboyshotrods.com
269-823-2967
rockdogz's Avatar
rockdogz rockdogz is offline
What are your intentions for the car?
-Tom
camarorestoration.com
Old 01-30-2007, 03:19 PM
Streetking's Avatar
I might do the power tour with it, run it at Pigeon Forge ect. I don't really want/ need a fuel injected motor since most of my other cars are. I need to decide if I want lighter weight for handling or big block power..
SW
Old 01-30-2007, 03:20 PM
4mm 4mm is offline
Hmm, I was going to tell you to skip the Camaro since you already have the same platform with the TA and buy a Cuda or Challenger.
But now that it's yours, I would maybe do a nice all aluminum SB2 or alum 454 small block? You already have a big block in the 69 Camaro.
Old 01-30-2007, 03:26 PM
zbugger's Avatar
zbugger zbugger is offline
I say de-stroke it to a 377 and rev it to hell and back. It'll make good power, and be a blast on a race track.
Old 01-30-2007, 03:31 PM
Streetking's Avatar
I was thinking about that, but this car just showed up.. I might do a Cuda next.
SW
Old 01-30-2007, 03:37 PM
romar 02 ss romar 02 ss is offline
Aluminum big block. All the fun at half the calories. Just my 2 cents.Good luck.
Old 01-30-2007, 03:38 PM
radrambler's Avatar
Default motor
sw
nice purchase...very nice and clean car...
i like the suggestion of an sb2 small block ..now that would be different and make gobs of power.....
i think you would enjoy the car more with the lighter motor and more useable horespower...im not in favor of the big block....
enjoy the new addition
radrambler
Old 01-30-2007, 03:48 PM
Lateral-g Moderator
You could put a carbeurated LS2 that will make about 550hp. Simple, no electronics.
SW, you da man.
