Old 02-09-2007, 09:24 AM
melman109's Avatar
melman109 melman109 is offline
Default Urethane VS Rubber bushings
What are the pros and cons of the 2? I've heard that the rubber ones are great but don't last as long as the urethane. But I have also heard that the urethane bushing tend to give you a sqeaky ride.
Old 02-09-2007, 11:06 AM
XcYZ's Avatar
XcYZ XcYZ is offline
I've heard guys fighting squeeking poly bushings forever and finally giving up and going back to rubber.
My LS7 69 Camaro
Old 02-09-2007, 11:12 AM
TravisB TravisB is offline
unless you need the stiffer bushings for a certain reason........go rubber
Kenny Davis Hot Rods
Old 02-09-2007, 12:27 PM
DAWG's Avatar
DAWG DAWG is offline
polygraphite is your answer.
no noise stiffer suspension
SIT DOWN _SHUT UP_HANG ON
Old 02-09-2007, 05:34 PM
sinned's Avatar
sinned sinned is offline
Rubber- works great, lasts along time, fairly cheap
Polyurethane- squeaky, cold flow properties result in control arm bushings taking set in oval shape leading to slop, no real improvement over fresh rubbers
Polygraphite- same cold flow issues as previously discussed with the added benefit of introducing a compound NOT compatible with urethane. The result is the graphite breaking down the urethane over time.
Teflon/Delrin/Nylon- eliminates all bushing compliance, lasts forever, not terribly expensive, impervious to the elements, no NVH issues.
Basically the Teflon option has zero drawbacks and lots of advantages.
Dennis
Old 02-09-2007, 08:12 PM
melman109's Avatar
Thanks guys! Damn I love this site
Old 02-10-2007, 10:48 AM
ProTouring442's Avatar
Put -squeak- PST "Polygraphite" bushings -squeak- in the -squeak- old man's -squeak- BelAir -squeak- and had to -squeak- drill and -squeak- add zerk -squeak- fittings to stop them from squeaking. Will probably destroy the bushings eventually, but at least they no longer squeak!
Shiny Side Up!
Bill
'72 442 "Inamorata"
www.FQuick.com/ProTouring442
Old 02-10-2007, 12:25 PM
Bandit's Avatar
Bandit Bandit is offline
Don't make fun of my car when you see me squeaking down the street, it's part of my sleeper image!
1980 Pontiac Trans Am, Chevy BB 402 + .010, TKO 600, Motive 3:73's, Hotchkis TVS, Coddington Junkyard Dog 18's, Nitto NT555 rubber, Autometers
