Old 02-28-2007, 09:30 PM
pano911 pano911 is offline
Default 1100hp street machine....help with rear end
Help!!! I'm doing a wild street car and need help with choosing parts.
69 malibu
509 Twin Turbo 1100hp 1100ft/lbs. (nelsonracingengines.com)
street tires 235/40/18 x 345/35/19
plan to back-half rear with tubs....need help with this!!!!
I'm thinking four-link with a 9-inch but not sure whose 4-link to go with....need input...Art Morrison? Chris Alston?, who?
Thanks!!!!
Old 02-28-2007, 10:57 PM
James OLC's Avatar
Lateral Dynamics 3-Link - No question.
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 02-28-2007, 11:22 PM
Hadn't seen that one, thanks!! Looks killer on their website.... Anyone else?
Old 02-28-2007, 11:41 PM
chicane's Avatar
chicane chicane is offline
With that much power.... you'll be hard pressed to find anything better.
Old 03-01-2007, 07:55 AM
Blown353 Blown353 is offline
Might I also suggest wider tires up front? You're going to want all the tire up front you can for braking that thing... 275's will fit on the front of an A-body without issue.
1969 Chevelle
Old 03-01-2007, 08:48 AM
mazspeed's Avatar
mazspeed mazspeed is offline
I would normally say this is a no brainer, but I don't know if it can handle that kind of power all the time. Not sure it's been tested as far as that kind of power.
Old 03-01-2007, 09:39 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Don't worry, it'll never hook anyways with a 19" street tire,
Old 03-01-2007, 10:48 AM
TLWiltman TLWiltman is offline
Well... he could use a floater axle. That should take care of any remaining power handling issues
Old 03-01-2007, 12:56 PM
From their website the Lateral Dynamics 3-link is not available for the A-body. Have a call in to them to see about custom apps but haven't heard back yet. Please explain floater axle...not familiar with this term....??? I also plan to have a set of 15x10 rears for screwing around at the strip with drag slicks....engine will be capable of 1800hp on race gas and of course I'll have to try this out even though the car will be used 99% street.
Old 03-01-2007, 01:49 PM
Speedster's Avatar
Speedster Speedster is offline
Did Tom already start on your TT BBC ?
-Bruce
Project "Freebird"
Dyno Video
http://www.nelsonracingengines.com/...lownbbchigh.wmv
Project Rides:
1968 Firebird - Blown 540
1987 Blazer 4x4 - Blown 355
2007 Magnum
2010 Camaro SS - LSX Twin Turbo
