Old 03-12-2007, 01:01 PM
Musclecar's Avatar
Musclecar Musclecar is offline
Default koni shocks
I purchased a DSE mini tub kit for my 69 camaro. I also purchased the Koni shocks to go with it (suggested by DSE). Are the koni shocks adjustable?
Carless at the moment
Old 03-12-2007, 01:09 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Yes, in compression/bump. There's a button on the bottom of the shock body that you press and hold while turning the shaft. There should be instructions in each of the Koni boxes.
My LS7 69 Camaro
Old 03-12-2007, 01:33 PM
Musclecar's Avatar
thanks
Old 03-16-2007, 12:19 PM
31 SONIC 31 SONIC is offline
The button is under a black plastic dust cover. Take a small flat head screw driver and pry the plastic cover down off the shock body. You'll see the button under that.
Old 03-16-2007, 03:15 PM
Musclecar's Avatar
I found it.. thanks again
