Old 03-20-2007, 10:07 AM
rsk68's Avatar
rsk68 rsk68 is offline
Default bent sub frame
Hi Guys
I need a little help, seems I have a little tweak in the stock subframe and am having trouble with the sheetmetal from this, does anyone have dimensions that i can use to check it and see how bad it is, if its not to bad i will have the frame shop pull on it, if its way out i may have to buy a new one. Oh its a 68 camaro.
RSK68
RSK68
Rick Klein
Hood-latches.com
Cast Aluminum hood latches.
Old 03-20-2007, 11:44 AM
907rs's Avatar
907rs 907rs is offline
Here ya go:
Bill
Old 03-21-2007, 02:27 AM
98ssnova's Avatar
98ssnova 98ssnova is offline
Would these be the same for 68-72 Nova?
Old 03-21-2007, 07:52 AM
rsk68's Avatar
Default bent subframe
Bill
thanks for the layout, i will try to take some dimensions and see whats up frame is in the car with motor installed so it may be dificult.
RSK68
Rick Klein
Hood-latches.com
