Old 04-27-2005, 11:57 AM
brian905 brian905 is offline
Default 69 max tire size?
Hi guys im noob here and wanted to know what is the max tire size (width) you can run on a 69 camaro without mini-tubbing it? Im picking up my first 69 camaro (dream car) and am trying to put together as much info as possible before starting anything. Thanks in advance
Old 04-27-2005, 12:07 PM
Payton King's Avatar
Default rear tire
275 is about as wide as you can go on 9.5 rim...10 possible. It will rub on driveways occasionally. I think the concensus is 275 on a 9.5 rim with disc brakes takes a 5.5 inch back spacing and take .20 off if running drums.
Hope this helps
Old 04-27-2005, 02:32 PM
69rs's Avatar
69rs 69rs is offline
I've been needing this too. What about the fronts?
Old 04-27-2005, 02:39 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Fronts:
245/45/17
17x8
4.75" of Backspace
Rears:
275/40/17
17x9.5
5.5" of Backspace
EDIT: Welcome to the site, Brian.
My LS7 69 Camaro
Old 04-27-2005, 02:50 PM
69rs's Avatar
Thanks, Scott. You're awesome! I knew that if I hung around long enough someone would ask! Good job, Brian. And welcome.
Old 04-27-2005, 03:03 PM
Ummgawa's Avatar
Ummgawa Ummgawa is offline
Jim
Where is Grayson? I'm west of Atlanta in Douglasville 10 miles past six flags
Jim
Jim
Old 04-28-2005, 12:34 AM
jannes_z-28's Avatar
Just an addition,
You also need to bend the innerlip of the fender, it will most probably make contact with the tires in bumps.
I have just the setup Scott mentions on mine (as a lot of others have) and it is just as much as you can get in there.
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
Old 04-28-2005, 05:21 AM
69rs's Avatar
Jim,
It's northeast of Atlanta, past Stone Mountain / Snellville area (Gwinnett County).
Jan,
I need to do that anyway. My current tires have a few slash marks from the inner fender.
Old 04-28-2005, 02:51 PM
Originally Posted by Ummgawa
Jim
Jim
You are? Really?? It says No Nookie, New Guinea in your signature. I didn't know Tarzan went there.
Jan
Jan Suhr
Stockholm, Sweden
