Old 06-18-2007, 07:06 PM
LS1NOVA LS1NOVA is offline
Default Anyone ever change there own backspacing
This is a steel rally wheel. I am considering cutting those welds and adjusting the backspacing. I could realign it on our Hunter tire balancer and then weld it all the way around with a nice Mig bead. Its not rocket science, anyone ever do it? This would make some 325/50r15s MT radials fit on my Nova for the strip.
Nate
71 Nova. "The Green Machine" April 11' PHR
Old 06-18-2007, 07:43 PM
GBodyGMachine's Avatar
GBodyGMachine GBodyGMachine is offline
You have to figure in the cost. You time is worth money. Is it more expensive to spend 6 hours redoing them or buying a new set? And I always just run spacers if I need to change the BS.
Jeff
84 Regal Project GBodyGMachine
[SIGPIC][/SIGPIC]
Old 06-18-2007, 08:00 PM
Well Im on a tight budget and a new set would be custom built. I need more backspacing, so no spacers.
Nate
Old 06-18-2007, 08:15 PM
Travis Rankin Travis Rankin is offline
the center piece is pressed in Very tight!
I can be done, but it will be a huge PITA
Metal Shaper
By Trade and Hobby
http://toyotatoday.ca/en/gallery/102
Old 07-04-2007, 10:20 AM
kmcanally kmcanally is offline
Default Weldcraft Wheels
I would contact these guys for all of your wheel modification needs www.weldcraftwheels.com
Kevin
Old 07-05-2007, 06:53 AM
XcYZ's Avatar
XcYZ XcYZ is offline
Getting it square so there's no run-out would be the big concern, but since you have access to a Hunter machine, you can check it. As Travis said, the center is extremely tight, you'll need a good press to get it to move once you grind all the welds out.
My LS7 69 Camaro
Old 07-05-2007, 08:43 AM
deuce_454's Avatar
a friend of mine who is neither a brain suegeon or rocket scientist by any stretch of imagination (you know the type) actually did just that and it worked fine, guess noone told him that he couldnt do it and so he did... he cut the welds and cleaned up teh inside of teh rim, then mounted the slicks (which is what he couldnt fit) and tapped the rim back and forwards till the BS was right on, then he mounted the rim on the ballancing machine (with a tack weld in one side of the center to the rom ring to minimize movement) in th eballang´cing mashine, runout could be checked with a super high tech white board marker, and where ever there was a mark the rim required a light tap, and after 10 minutes of tapping it was remarkably straight... the rims are now fully welded and you cannot feel any vibration or detect funny wear, so my acvice is to just do it...
Jake: Hit it.
