Champion Cooling’s new Electric Fan Controller steps up your game to the next level when it comes to cooling systems. Their new, Bluetooth ready controller allows you more control over your cooling fans; the free app can be downloaded for IOS or Android devices, allowing you to set separate on and off temperatures, whether you have a single cooling fan or dual cooling fans. Each relay is labeled with the proper connections for an easier installation, and the included harness is hard-wired to each relay.
The Fan Controller will work with OE or aftermarket temperature senders, or when used with most Dakota Digital instrument clusters the included patch harness plugs directly into the main control box to access coolant temperature. The thorough instruction guide provides several full-color diagrams for several applications, using OE or aftermarket instrumentation.
For More Information Visit ChampionCooling.com
